Early 80s Pug tandem....
#51
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Maybe you know this already but for anyone who doesn't: the stoker never needs to stand over the TT, so standover becomes less important. See if your stoke is OK with mounting as on a horse: put one foot in the near side pedal, then throw the other leg over, with cap'n steadying the bike. "Play the film in reverse" to dismount. Lots of stokers like this way just fine as long as cappy remembers to spread his feet wide and brace the bike well, no wiggle while she's mounting or dismounting.
Mark B
Mark B
New stem & bar tape arrived today, so that’s on the agenda for tomorrow.
#52
Quoted: 761 Post(s)
Liked 1,563 Times
Maiden voyage today. Somehow in about 6 miles we managed to ride in a busy 'city', narrow country roads with people driving waaaaaay too fast, some gravel, some grass, a few small hills.....
Still some sorting out to do with the FD (doesn't want to consistently drop down to the granny), stoker's seat position..... Original fenders are too narrow to clear the 38c tires, but I've got a set of hammered 'Mud Butlers' that will, so that's next on the list...
#53
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
Likes For L134:
#54
Quoted: 761 Post(s)
Liked 1,563 Times
Hm, that's an idea. I did have the Simplex SLJ FD that's on the tandem working with a triple on another bike, and the 'geometry' etc looks pretty much the same. I'm wondering if maybe the short bit of housing that runs from the stop and under the bottom bracket then up to the FD is creating enough drag that the FD won't 'release' all the way to get the chain onto the granny. It almost shifts/drops the chain down onto the ring, just not quite. If I just push it a little bit with my thumb it makes the shift- and then I have to trim it back a bit so the outer cage doesn't rub. More tinkering in order....
#55
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
ehcoplex , nice tandem. Sorry. I've been remiss about responding.
That bike is much like the one my sweetie and I have been riding for quite a few years now, '82 TH8. I equipped it with as many original or original-like components as I could manage, and then added some.
Here are a few pics.
I rigged the brake cables as per original, dual cables on the right hand, drum on the left. The rear hub is original, but I have restrung the wheel. The original Simpex RD would have worn out long ago but the metal versions actually work quite well.
There is, or at least was not too many years ago, a new (not NOS) Simplex all-metal replacement version of the original. It works very well.
As you can see, I did some mods on this one. The stoker's crank is a mtb crank, Andel I think, cut down to 140mm by Mark Stonich at Bike Design and Fabrications (IIRC). I had to adapt a Shimano canti-brake spring for one of the cantis, and it has Koolstop pads, but the rest of the brake system is original. A few other items are original too. The gearing is 3x5. It has been a reliable and comfortable bike over thousands of miles.
BTW, the advice bulgie gave you about the stoker not needing to straddle the bike is accurate. My sweetie can't straddle her TT. I hold the bike steady while she mounts, then we ride away. Stopping is the reverse procedure.
Real cyclists use toe clips.
jimmuller
jimmuller
Likes For jimmuller:
#56
Quoted: 761 Post(s)
Liked 1,563 Times
We did use the technique bulgie posted about for mounting and dismounting, & it worked well! The hardest part of the 'maiden voyage' was that we were riding with some friends (including a couple kids), so the pace was varied and inconsistent- a lot of "and....coast.....", "...and.......pedal.......", "and....coast....."
#57
Liked 645 Times
The original rear hub should be an Atom, I believe. I wouldn't think there is much difference between the various options. I tried to keep our bike as original as possible just "because", which is to for aesthetics that have nothing to do with riding other than that we and other cyclists think it is cool.
jimmuller
jimmuller
#58
Quoted: 4513 Post(s)
Liked 6,392 Times
Glad you are forging ahead, ms. ehco still/all in at this point?
Likes For merziac:
#59
Quoted: 761 Post(s)
Liked 1,563 Times
Yup- I have the original wheels with the Atom rear drum hub. The rims are Chrolux, and in terrible shape. Maybe I'll rebuild the hub and use it with a new rim... but more likely I'll use the Sansin hub. What are the rims you've got on yours?
#60
Quoted: 761 Post(s)
Liked 1,563 Times
- She did declare the ride a 'success'.... though it wasn't a very hilly ride- it remains to be seen how the significant hills around us shape attitude going forward...!
Likes For ehcoplex:
#61
Liked 645 Times
Our first rides were fairly short, maybe 5 miles, with the goal of being able to handle the stress and eventually increase the mileage. It was stressful. As my sweetie became more comfortable we started increasing our mileage. Our longest ride was 72 miles, but I don't think I want to do that again. Around here the hard part is finding the route!
jimmuller
jimmuller
#62
Liked 6,392 Times
Anytime something new gets off on the right foot, wheel, roll, it can make all the difference especially this endeavor, I truly believe this is not for the faint of heart and a true test of each others resolve at some or many points.
I saw a couple on a beautiful CoMotion tandem Sat. at Crater Lake they were all in and having a blast. No pics but I was inspired to slog on in my struggle and it didn't help much but that was me.
Likes For merziac:
#63
Quoted: 761 Post(s)
Liked 1,563 Times
A short ride yesterday to our local farm-brewery- only about 5 miles, but with a couple steep little stretches and it was all good. Going to ride some more this afternoon.
Having some issues getting the FD to shift down from the middle to the small ring (and sometimes from the large to the middle.....). I did have this FD working on a triple on my PX-10, so I'm not really sure why it's not doing so well on the tandem. More tinkering necessary..... And considering bar-ends and a reverse-pull FD (and may go full Suntour in that case).
Also trying to sort of an elegant/effective way to add some bottle cages... I thought the King Cage universal clamps were the ticket, but unfortunately the orientation of the cage-bolt-tab is such that the clamp screw interferes with the DR cables on the down-tube... It may be sacrilege, but I am considering Riv-nuts...... maybe.... I mean, it's not like it's a high-end frame, etc....
#64
Quoted: 761 Post(s)
Liked 1,563 Times
Added some fenders I pulled from another bike I don't really ride much now....
#65
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
Dunno if this idea will appeal, it's a little dorky-looking but effective:
Two small bungies, from the back of each cap'n pedal to the front of each stoker pedal (toe clip, if installed)
It means never again having to flip your pedal up to get the toeclip pointing the right way. Never again dragging a clip on the pavement before you get that foot into the clip. It alsdo allows you to ride the tandem solo even if the stoker has toke lips.
Get the smallest-diameter bungies with the smallest hooks you can find, to minimize weight (ha!) and dorky look. They're under practically zero strain, as long as you don't have to stretch them too tight. Two pieces of string tied to the pedals would also work, though not as quick to install or remove. You don't actually need the springiness of bungies, the pedals always stay the same distance from each other.
Assuming your pedals are in sync that is. I don't see tandem out of phase (OOP) much anymore but it was a popular tactic BITD, with pros and cons. The wife and I tried it, went back to in-phase, but others stuck with OOP for mega-miles. It does make some drivetrain parts last longer since peak loads are lower, and some folks say it makes starting on a steep uphill easier. But no bungie-pedals trick possible with OOP.
Mark B
Mark B
Likes For bulgie:
#66
Quoted: 761 Post(s)
Liked 1,563 Times
Mark B
Mark B
I seem to recall reading somewhere recently that OOP was less efficient on hills, but I could totally have that wrong. Trick at the moment for us is finding the right cadence- I'm used to spinning, she prefers grinding (to an extent).. But I think that may be more a lack of a lot of cycling experience. Well, and also significantly shorter legs. Ideally I'd probably have 172.5 or even 175 cranks and she'd have 165.... But we're making it work and having fun (a coffee shop or brewery as a destination definitely helps)!
#67
Liked 2,576 Times
Anyway I'm pretty sure you'd show very little difference in efficiency, if any beyond the margin of error of your measuring method. If someone came up with a large difference, I'd suspect something wrong with their experimental design, because that wouldn't jibe with some other known facts. Namely that riders using OOP often have no trouble keeping up on hills! People who've tried both seldom report any personal records falling by a lot after they made the switch.
For me, the decision to switch back to in-phase was made based on intangibles like "teamness", being metaphorically in sync with your partner as well as literally. Also OOP tandems just look funny, especially when the team is pedaling, there's something "wrong" about it. Based purely on what I'm used to, but still, it is a factor for me. I just love the look of an in-sync tandem team.
Early Santanas were delivered OOP, until at some point even Santana decided not to swim against the tide, and they switched to in in-phase. I don't remember how they described the difference or their reasoning in switching, but I'm suspicious that some of it was just that in-phase tandems were easier to sell.
Mark B
Likes For bulgie:
#68
Quoted: 761 Post(s)
Liked 1,563 Times
Further thoughts after a few short rides... So far, going up modest hills isn't as tough as I thought it might be, and going down a hill......wow a tandem picks up speed fast!
I had thought having an indexed rear might be a good thing while getting used to a tandem, but I've discovered that I guess I really am a retro-grouch and much prefer friction shifting (easily accomplished by turning the shifter from 'sis' to 'friction'...). Reaching for the down-tube to shift on a tandem isn't all that fun, so I'm going to put bar-ends on (in the case of DT shifters, I move both rear and front with my right hand, and the extra double-stays that run from the head-tube to the rear drop-outs kind of get in the way of using my right hand to shift the FD).
Realizing that I don't like randonneur-bend bars that much (or wide bars.... I thought wider might be better, leverage-wise on a tandem..), so at some point I'll find some narrower, parallel bend bars like I have on my PX-10. So much for assuming I'd get along with these bars (they'd been on another bike and I'd forgotten that I never really liked them that much). Ah well, so much for assuming, and doing all the work of shellacking the tape.
Thinking about a rack for some panniers. On a single I prefer the weight up front, but I wonder if the same will be the case with this tandem. Logically, at least to me, it makes sense to distribute any load more toward the front to even things out. I suppose the only thing to do it try different setups out..
Likes For ehcoplex:
#69
Quoted: 5888 Post(s)
Liked 3,472 Times
Nice write up. There is a gitane tandem local to me that is tempting but I'm trying to resist . . .
#70
Quoted: 761 Post(s)
Liked 1,563 Times
#71
Liked 3,472 Times
#72
Quoted: 761 Post(s)
Liked 1,563 Times
#73
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,009 Times
As far as the weight goes, unless you are carrying touring loads, you aren't going to notice a few pounds on either the front or rear because of the overall length of the frame and it is such a small fraction of the riders' weights. I did a few solo test rides and was surprised how much more sluggish the bike felt with my wife on board.
#74
Quoted: 761 Post(s)
Liked 1,563 Times
Ha- the other day after an 8 or so mi ride on the tandem I got on my PX-10 for a longer solo ride and almost fell off! I'd gotten used to the awkwardness/sluggishness of the tandem and the solo bike squirreled all over for the first minute or two!
#75
Liked 2,576 Times
Your Peugeot is a much better bike.
Mark B
