Tommasini barn find? Help needed.
Señor Member
Quoted: 284 Post(s)
Liked 301 Times
Wrong tube.
Your pics are of the head tube (part of bike frame), while @T-Mar was referencing the steerer tube, which is part of the fork. Helical ridges will be on the bottom of the tube only if there.
Quoted: 9 Post(s)
Sorry about that. My technical English needs improvement. It's not so easy to translate everything. I've uploaded pics of the fork as well now.
Quoted: 821 Post(s)
Liked 257 Times
Wish my Spanish and German were as proficient as your English.
btw Interesting bike you have there. I've owned two Tommasini Racing framesets.
Neither of mine had a panto'd fork. In fact, both of mine looked quite similar to yours.
Fun thread.
Quoted: 9 Post(s)
You are doing a great job with your English.
Fun thread.
Fun thread.
So i can get inspiration for the rebuild...
Quoted: 4722 Post(s)
Liked 3,039 Times
Here's a picture of what the helical ridges look like inside the bottom of the fork's steerer tube. Alternately, since you've removed the fork, you can check for Columbus' dove logo on the outside of the steerer tube. If neither are present, then either the fork is a replacement or it's a Columbus tretubi frame (i.e main tubes are Columbus SL, while forks and stays are lesser grade material). As previously noted by myself and confirmed by gomango, Tommasini did market forks without embossing.
Quoted: 9 Post(s)
Now it's clear to me. Thx T-Mar.
New pics taken and uploaded.
But no helical ridges or Columbus marking. Only a ' T ' on the steerer tube.
' T ' for Tommasini or too bad.
Quoted: 569 Post(s)
Liked 595 Times
Looking forward to seeing you build completed.
Edumacator
Quoted: 2455 Post(s)
Liked 3,170 Times
Honestly, the fork works with the way the bike looks. I would spend the money on getting decent components as they need replacement, and giving the whole frame and fork a nice cleaning. Great bike as is. Especially if the fork pitting and rust is just surface.
Just enjoy the ride!
Liked 3,039 Times
+1, given the lack of embossing on the frame itself, I'd leave the current fork. It appears to be OEM and while later Tommasini forks are readily available, a period correct fork with the chainring embossing will be harder to find and getting one with the minimum required length is going to be even harder.
It's definitely not a Columbus SL fork. I haven't seen any Tommasini from this era below Columbus SL tretubi level, so that's what I would assume it to be. However, to confirm this and rule out Aelle, you should check the seat post size, which should be stamped on it. That will give a good indication of the tubeset used for the main triangle.
Quoted: 9 Post(s)
Just checked the seat post. It says 3 ttt and 27.2. Now i have one problem left. It is really stuck in there. Any tips on how to get it out? I've sprayed it with wd40 several times, tried to move it with a wrench but no luck.
Quoted: 821 Post(s)
Liked 257 Times
My Flickr will no longer be updated for bikes. I used it for show and tell purposes, but I’m more interested in online privacy nowadays.
If it were me, I would just clean up the frameset, collect the needed bits and build it. If you are dropping money into it as a rider, you should be fine.
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Agreed with T-mar and the other Learned Elders, clean up that fork, as well as the frame, and put it together as a rider. You can round up the necessary components of your choice and budget level to complete the bike, and you'll have a nice riding, enjoyable bicycle for yourself.
Bill
Bill
Semper Fi, USMC, 1975-1977
Liked 3,039 Times
There are literally dozens of methods that can be used in an attempt to extract a stuck seat post. Here's a primer from the late, great Sheldon Brown. https://sheldonbrown.com/stuck-seatposts.html
Quoted: 9 Post(s)
So, the frame is stripped from all parts, except the seat stem. I'm going to give up trying to save it and just cut it and drill it out.
Since the frame seems to be repainted allready, i've decided to sandblast and powdercoat it. Any ideas of a period correct colour scheme?
And where to get new decals?
Thanks for all the help.
