In which direction do you tape your handlebars ?
#54
Fresh Garbage
#55
Bikes: 2008 Surly Cross Check, 2010 Fuji Track Comp
Quoted: 255 Post(s)
I've been waiting for this one to come around again... (vanity be my name )
I wrap mine from the stem out, like this
Sorry for the cellphone pics. I'll get a good photo of the red and white ones on the bike, outdoors, tomorrow. The blue and orange wore out due to use, and have been replaced with simple orange cork, wrapped from the stem out, clockwise.
#56
sɹɐʇsɟoןןnɟsʇıbɟɯo
Bikes: fixed gear recumbent trike
wish i could figure out the harlequin wrap
#57
Still kicking.
Where it's double stitched, is air cushioning, and soaks up vibrations extremely well. It's a very comfortable bar tape.
Appreciate the old bikes more than the new.
#58
Question for those of you using Lizard Skins: With other self adhesive bar tapes I've used, the adhesive and part of the wrap usually tears off and leaves a lot of bar tape and residue on the bars. Does Lizard Skins do this or does it come off pretty clean?
Also, what does cloth tape with schellac feel like, hairnet? It looks like it would get sweaty and slippery. Definitely a good wrap job and a cool vintage look though!
Bar ends -> stem, over the top away from the tt. Finish with electrical tape and a drop of gorilla glue to keep the tape end from peeling.
#59
Quoted: 255 Post(s)
When I did the blue/orange set last year, I followed these instructions. I did the red/white set last week without any instructions. It mostly takes patience, it took me a couple hours per set, at least. I like to put on a movie while I do it, too. ("Ivan Vasilievich Changes Profession" during the blue/orange set, and "Running Man" during the red/white set )
Also, and I don't think it is mentioned in the instructions, it helps if you use a twist tie or a zip tie or a velcro strap of some kind to keep the rolled up tape from unrolling, since you may need to set it down or let it hang occasionally to be able to work with the overlap. Also, if it isn't mentioned in the instructions, it helps to keep the tension consistent so that your pattern doesn't "wander" around the bars too much. (see the non-bell side of the blue/orange set)
jyl
Bicycle Mechanics
45
02-18-12 10:29 PM
