How much better are Weinmann Centerpulls than Sidepulls?
When I went through the Chicago factory school for Schwinn Approved mechanic certification in the '70's we were shown the proper technique using the two 10mm Weinmann open/closed brake wrenches to reliably center Varsity brakes: No violence required.
That being said I have the choice on my town bike to use a variety of C&V calipers from my stock and go w/ Weinmann 610 center-pulls: simple, reliable and effective enough.
Brakes will only slow you down, I've never gotten obsessed w/ something that I use as little as possible.
-Bandera
-Bandera
Likes For Bandera:
People who have only ridden bikes with dual pivots or V brakes will try old brakes and say they "don't work" but it's because they're not used to squeezing hard enough. Not everyone is strong enough. If you're strong enough and don't mind squeezing hard, the 605s will be fine.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Centering Side Pull Brakes
In the past year I've had the pleasure of overhauling Weinmann 605 brake calipers plus DiaCompe levers and DiaCompe 610 calipers. I wasn't aware of the differences in the springs but just about every thing else between the 2 brands interchange.
I took the suicide levers off of a set of DiaCompe levers and replaced the red pivot pins with Weinmann ones, also the nylon bushings. Those bushing wear quickly especially with the angular torque applied by the suicide levers. Replacing the bushings makes a big difference in the levers.
The later version DiaCompe center pulls came with decent pads that have a lot of stopping power. Again, I sand down the faces of all of my brake pads whether new or replacements or during servicing.
3M makes a product called Drywall Sanding Screen. It's inexpensive and you can get it at hardware and paint stores. Medium grit works well for sanding down the braking surfaces of pads.
I put a sheet of paper on a flat surface and put the screen on top of it (the paper makes it easy to collect and dispose of the dust). A few minutes per pad making sure the faces are square to the holders and it's done. taking 1mm of old hard pad face takes a little longer.
Screen Cloth looks like this:
I have Weinmann 999 brakes on my 1965 Tigra. The caliper arms are beefier than on later 610/750 brakes.
Old Weinmann 500 style side pulls on a 1960 Schwinn Paramount
Notice both style brakes have short 3 Dot brake pads.
verktyg
Chas. ;-)
Chas. ;-)
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Of course, some (myself included) may not accept flexy brake arms on their machines, so this is where it boils down to personal preference.
However - with that said - this does not seem to prevent many people (or mechanics) from trying to use them improperly with narrow rims and C&V-style brake pads. The gap results in pads that get swung upwards at a 10 degree angle to meet the rim surface as the caliper arms are overextended.
I don't consider such a setup correct, nor a valid metric to critique the performance of the 999/610/750 upon. It is possible to compensate by running a modern pad with enough thread to allow for some inboard shimming, but most C&V pads don't have enough threads to allow someone to put a washer between the pad and the caliper on the inside.
-Kurt
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I'm surprised nobody has mentioned rim width in regards to centerpulls either. The Weinmann 999/610/750 and the Dia-Compe copies are made for wide rims. The brake arms are placed well apart from each other; enough so that factory Weinmann pads and similar copies are usually not wide enough to be used in conjunction with many popular road rims of the era (Super Champions, Rigida AL1320's, etc).
-Kurt
-Kurt
FWIW I've been riding the Gran Compe 610 reissues with Velocity A23 rims for the last several years, and they work just fine. As one might guess, A23 rims are 23mm wide. That's basically the same as old Super champ 58, and Weinmann concaves, IIRC.
Rigida 1320 were more like 19mm I think. Didn't stop Motobecane (et al) from spec'ing them with Weinmanns on many different bikes BITD. Didn't 1320 have slightly angled sides? That probably helped a bit.
leicanthrope
Classic & Vintage
2
10-16-13 05:35 PM
