Racer Tech Thread
#5301
Quoted: 693 Post(s)
Regarding longer spindles. A small part of this book (https://www.bloomsbury.com/uk/bike-fit-9781408190302/ by Team Sky's fitter) talks about how in today's state of the art bike fit science, the "stance width" (q-factor, essentially) is a very ill-understood and highly overlooked portion of a bike fit. IIRC, he essentially says that if you have duck feet and if you have crank rub, then consider getting longer spindles
Q is a factor of the crank only.
2 pedals can have the same spindle length, but the effective width based on the platform is different.
cleat position is limited by the cleat type (duh) and shoe.
i guess one could argue that the shoe can affect stance, as some shoes allow more adjustment than others, thought it's not *usually* a width thing.
#5302
Bikes: 1979 Raleigh Team 753
Quoted: 3377 Post(s)
Liked 371 Times
Ignore the spin here (or not) and look at the bearing width. Similar Q factor but instead of a BB30 and flared cranks, these are more straight cranks and wider bearings (and steel 24mm spindles).
#5303
Quoted: 693 Post(s)
https://youtu.be/dlQrvB530qQ
are you introducing a new hypothesis that there is something notable about how Q is achieved?
#5304
Blast from the Past
A better solution for the skin on my ankles turned out to be BB30. For those of us who toe out a curved crank arm, like a Hollowgram, offers a lot more fit options w/o having to compromise something like Q or cleat position.
#5305
Liked 371 Times
The Specalized cranks went from the narrower bearing stance to the pedals - they "flared" more. The Shimano went from the wider bearing stance and flared less. I expect, but did not measure, the Q factors were close between the two.
#5306
Quoted: 693 Post(s)
No. That bike had BB30, and had the Specalized carbon cranks. I don't have those in the video, but they are well known. I replaced them with the wider bearing stance - 20mm or so, put the S carbon on the SHIV.
It is possible that 2 cranksets can have different spindle widths and the same Q, which of course necessitates different arm shape. There are always situations where a crankset with narrow spindle can match the Q of wider cranks (in theory) but the reverse is not true.
#5308
Quoted: 693 Post(s)
... only worth more when it is something too difficult to describe in words or a single still image.
seriously, had your video even showed a comparison of something, then it might be more interesting, but we already know what a straight crank-arm looks like, and "wide" is only so when presented in contrast to something.
we know.
i think wide & small diameter works, as does narrow and large diameter, as does wide and large diameter. each have advantages and disadvantages.
there are people who will argue that peak-bottom-bracket was achieved @ square taper...
Originally Posted by doge
And I think aside from Q factor I like wider smaller diameter bearings.
#5309
Quoted: 693 Post(s)
however, as an example i ride on the road a fair bit and ride MTB -- and recently had to switch from 156Q to 168Q on my MTB and don't consider it an issue, mainly because my position is less static on the MTB; others disagree. there is also way more lateral movement on the pedal for the average MTB rider vs road.
#5311
Quoted: 693 Post(s)
you can see why it was a little confusing to someone reading.
Most the team 2015/2016 went to the wider BB bearings.
#5312
Liked 371 Times
of course i can't keep track of your bikes, but you wrote that you had a BB30 bike with SW carbon cranks (sounds like a specialized bike) and you moved those cranks to the shiv (shivs have always come with cranks from specialized, but maybe it was supplied without cranks, which would be a little odd if you have to run specialized stuff for sponsor reasons).
guess with what you've wrote that could be sponsor reasons or something else altogether.
I can't keep track of my bikes. I have bikes I bought and bikes I get. Parts are traded, borrowed, returned - sometimes. Most the stuff now - I own, team bikes went back. Junior is off buying his own stuff now too. He must have about 6 bikes at the academy and another 8-9 he is responsible for and is in charge of bike stuff procurement. So nothing is getting clearer. I first worked for a guy in the 80s who had some 100 plus bikes. So this is all "normal".
Most the team members own bikes and ride 1-2 bike they don't own. In 2016 I got a pile of new stuff in boxes, some used stuff, some new frames with parts removed.
My comment was about crank bearing width and flared cranks / Q / pedals not explaining what comes on what. Sorry to mention it.
Another video - this year, and you can see the mess that a few kids have. Guessing 2.2 bikes/kid.
#5313
Quoted: 693 Post(s)
It is confusing.
https://youtu.be/jHlO4Q_gl1g
guessing it is a video that shows many bikes, and i've seen bikes before. i can look in my garage for an image of that. :-)
hee hee
#5314
Cat 2
I can vouch for @tetonrider 's garage. I was in awe to see so much nice stuff. My collection currently sits in a home made PVC bike rack that does the job.
#5315
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
did you all ever decide on which smart trainer is currently the best? It's going to start raining here sooner than later I think.
#5316
Liked 371 Times
I did review the link.
My wife wore a few out and has a bike permanently on one. I prefer her off that thing and riding/running with me.
Son has the snow issue, but only using rollers and watching movies. I think that is OK. And last week he got clearance to do track, so likely not needed there. And we can't share.
I likely would try 1-2 times and see max sprint and quit.
Zwift?
So doing nothing.
Zwift?
So doing nothing.
#5317
Cat 2
I have a kickr2. I like it a lot. I had a kickr snap last winter. It was okay. Definitely made me a better cyclist, but I like the wheel off better.
For reference I've also ridden a ****ty trainer, and I ride rollers for race warmups or easy spins when I want something more active than the smart trainer. Check out the DCrainmaker review that he just put out. You really can't go wrong.
#5318
**** that
Quoted: 1099 Post(s)
Liked 104 Times
HTFU and let's ride in the rain!
I might even get a new fender. After 5 years or whatever I think the one I have is just about done..
#5319
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Did you guys bring a semi to carry all of that stuff!
Wow. Enough to make most bike shops jealous.
#5320
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
I'm interested in which fenders you're considering. Especially after having done intervals in a frog-strangler yesterday.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#5322
Liked 371 Times
I posted that to justify why I was sometimes confused on cranks/bikes. The year before I built several, swapped parts and bike for, old bikes, personally owned, rider owned, team owned and Specalized. It gets mixed up in my head.
The personal owned bikes (inc directors kid) tended to have the BB and Shimano cranks I was mentioning and it made them easier to pick out (Fancy paint jobs helped too).
#5324
once a runner
Bikes: n+1
Quoted: 270 Post(s)
After crashing on bad roads several times this year I think I'm not going to be risking any rain rides this time around. I should probably sell my spare bike...
#5325
¯\_(ツ)_/¯
Quoted: 967 Post(s)
I don't have a rain bike anymore, btw. I have 2 race bikes!
I will probably get this for the inbetween days https://www.kickstarter.com/projects...cycle-mudguard
