Racer Tech Thread
#2476
Bikes: Scott Foil 10, Di2
Quoted: 148 Post(s)
Well, the big difference in the frame upgrade is that you get the one piece bar/stem, which you don't get with the 10. So one possibility is get the HMX with the one piece bar/stem, but put Ultegra Di2 on it (which is the groupset on the 10).
#2477
Quoted: 2953 Post(s)
Liked 3,106 Times
Yeah, no clamp on for the 1x Allez Sprint, but there's a 2x version coming soon.
Decisions decisions. What frams?
- Tarmac just like the one I broke
- Venge (not the fancy one)
- Allez Sprint, which I am really interested in, but would have to drive like 2 hours to demo, and didn't have a great experience with my last specialized alu bike so hmph
- Supersix
- Supersix
#2478
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
I love my scott foil, but my next bike will have hidden front brakes. It's a real advantage.
#2480
Liked 3,106 Times
#2481
Quoted: 1852 Post(s)
Liked 679 Times
I've got a Caad 10 arriving this week to replace the frame that was cracked in my encounter last month with a car.
I briefly considered waiting for the Allez Sprint to come out with the FD hanger - while the bike will mostly be used in crits and I don't really need a little ring for those, I'd like the bike to be a bit more versatile than just racing crits.
BUT, it's a really expensive aluminum frame. Even with a discount, it would still be about $1000 - almost twice what I'm paying for a brand new Caad 10. And aluminum at that price isn't much of a value. If you crash it, there's a good chance it will dent and crack. Aluminum can't be repaired. A carbon fiber frame could.
#2482
Edit: Super Secret Insider Knowledge Check indicates that a CAAD12 frameset is currently not available. When/if when will be available, I do not know. I suspect it will, but it may take some time.
2nd edit: actually, it appears that a CAAD12 frameset WILL be available eventually. For pricing, let's just say it will compare very favorably to the CAAD10.
#2483
fuggitivo solitario
changing cables on this bike is a total PITA, and you'll have to have a shop do it for you. I do most of my own wrenching, but changing derailleur cable is one thing i don't have patience for, and i'd gladly pay them $20 per cable to do it.
Only downside about the bike is the bottom bracket. Pressfit is the spawn of the devil.
#2484
Liked 679 Times
I bought a 30m spool of cable liner for like $9 for this purpose.
#2486
Quoted: 148 Post(s)
get the one with Di2
So the question is really: is it worth the extra however much (maybe $1000) for the HMX build vs HMF.
#2487
fuggitivo solitario
worth is a how tall of a tree question that only you can answer
if it were up to I, I would get the cheaper one and buy an aero handlebar and call it a day. Difference (in CdA) of that setup vs one with integrated bars is probably minimal
#2488
Rides too much bike
Quoted: 232 Post(s)
Quoted: 31 Post(s)
I have no interest in a 1 piece bar/stem; so I'd def get the 10
#2492
Liked 679 Times
I think this is where I ordered it: Jagwire Black Housing Liner 30 Meter Roll, Fits up to 1.8mm Cables in Tree Fort Bikes Other Cable/Housing Parts (cat1292)
For awhile, I tried running sections of liner through the tubes to see if it improved shifting, but I didn't really notice it. I do find a short length of liner with a few rubber grommets helps reduce noise on the rear brake cable. Mostly I just cut sections that are about 6-10 inches longer than the run in the frame for use when replacing cables. The liner can get kinked when I tape it to the frame to keep it from falling out so having plenty of liner is nice. I just throw it away when it is too kinked.
The difference in the frames will largely be weight. Maybe 100 to 150 grams. I went from a 2013 Argon to a 2014 and the frame dropped about 150g between the two years. I didn't really notice it though. (Change was due to a warranty issue.)
As for the one-piece bar stem, I am not a fan of the concept. Over the years, I have changed stems too many times, going with different lengths or angles. And I am particular about the rotation of my bars in the stem. But, I do see how they could be more aerodynamic and lighter weight. So, if the bar/stem combo comes in the stem length and angle you want and the bar rotation is where you want it, then go for it. I know several people who use them and really seem to like them.
Maybe I wasn't clear: my dilemma is between spending the extra for the HMX frame with the one piece, integrated bars...or the HMF frame with an integrated headset but standard bars. Whichever frame I get, it'll be with Ultegra Di2.
#2493
Liked 679 Times
Saw that Sram released MSRP pricing for its new electronic groupset today: $2758 for everything. (https://www.sram.com/stories/introducing-sram-red-etap)
Based on my math, it looks like just the shifters, derailleurs, charges and USB would be about $1550.
Both numbers seems like reasonable - based on costs for DA 9070 and Campy EPS - prices to me for electronic shifting but I am still running 10-speed mechanical with little incentive to change.
If I were to go this route, I'd probably wait for the Force version.
#2494
Ninny
Quoted: 686 Post(s)
Oh yeah, been waiting for this info. They have satellite shifters, which will require a control box that appears to be about the size of a Garmin 500 (they say it fits a Garmin mount). They describe them as TT-specific, so it's not clear if they can be run in addition to regular shifters, or instead of regular shifters.
Since there's only one paddle per side, though, sprint shifters are maybe less useful than with Shimano Di2, since all you have to do is stab at one paddle or the other to shift from the drops.
[edit] What I wrote above is incorrect. The satellite shifters can be either plugged into the shifters, or on a TT bike with no shifters, can be plugged into a control box. So they can operate just like Shimano di2 satellite shifters. Though as grolby says below, as flat buttons they might not be as usable as sprint shifters compared to Shimano's pointy buttons.
#2495
Rides too much bike
Quoted: 232 Post(s)
Wireless is something that makes me nervous to be honest. I have seen plenty of things go wrong with ANT+ sensors, batteries that crap out after a week, etc.
The idea of trusting my shifting to wireless transmission is just not that awesome to me. I hope to be proved wrong but I am definitely waiting a generation or two to move from wired electronic to wireless.
#2496
I think the new group looks pretty interesting, I'm not in a big hurry to make the upgrade or anything, but I like what I see. And while I have questions about some specific use cases, I very much like that SRAM rethought the shift logic they could employ when freed from the constraints of mechanical cables. We'll see how this performs in the field at mass production scale, but I do think this is pushing the technology forward in a couple of really good ways.
#2497
