Threadless Conversion Headset
Old 07-11-20, 05:37 AM
  #176
I’m a little Surly
Germany_chris's Avatar
Quoted: 699 Post(s)
Liked 1,294 Times in 647 Posts
Originally Posted by joejack951
Classy looking build! Beautiful frame and your color and component choices all compliment it nicely.
Thank you! Let us know when you get more in stock. I have another bike that’s going to get one with some granola bars this winter so I have gasthaus bike.
Germany_chris is offline
Old 07-13-20, 07:56 AM
  #177
joejack951's Avatar
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
Quoted: 1242 Post(s)
Liked 94 Times in 65 Posts
Will do!
For this production run, I kept everything generally the same as before but I couldn't let a few things go unchanged, having had a lot of time to think about the design.
1. As mentioned earlier in this thread, I have added the M5 threads to the threaded shaft allowing use of standard threadless top caps. As with a typical threadless installation, the steerer tube/quill will need to be cut a few millimeters short of the top of the stem or a spacer will need to be installed above the stem to allow the threadless top cap to fit properly (most protrude a few millimeters on the underside). In this configuration, you could then use the top cap screw to compress the spacers (or bell zenolee ) so that they don't rattle, assuming you are using non-innicycle spacers. Probably not something most will care about but it was a simple change so why not.
2. Weight weenie'ism is an infection I'll never cure and while I was initially concerned about using aluminum for the cone/wedge, I have decided that there's little to no risk in doing so. It saves >10 grams which, combined with a steerer tube and threaded shaft trim, bring the total system weight down an even more respectable level and within a couple grams of my abandoned ultimate-weenie design that was going to have a lot of compromises. A titanium shaft could cut another a few grams and ceramic bearings would chop a few more but we're getting into overly expensive territory quickly when things start going in that direction. I think I'm happy with where it currently stands with this one modification.
That's it for changes. Expect another update from me in about 5-6 weeks. Of course, I'm happy to answer questions in the meantime and do have a few silver headsets available still. This next run has been heavily biased toward the black unit which seems to be the prevailing color preference (both of my innicycle builds have used black headsets). I'm also continuing to toy with stem ideas though my focus has recently been diverted back to my thru axle fork project with the completion of a new kit for some popular Trek bikes:
joejack951 is offline
Old 07-13-20, 08:27 PM
  #178
Hi, Just curious. You mentioned that you still have a few silver headsets available, but it says unavailable on amazon. Is there another website i can order from or directly from you? p,s, i live in canada, dont know if that makes a difference. Thanks.
ceester is offline
Old 07-22-20, 10:55 AM
  #179
Sunshine
mstateglfr's Avatar
Quoted: 10971 Post(s)
Liked 7,498 Times in 4,194 Posts
End product. Not yet cut(not sure if I will, need some miles).
mstateglfr is offline
Likes For mstateglfr:
Old 07-22-20, 11:29 AM
  #180
joejack951's Avatar
Sorry for my slow response. Silver headsets are available by direct order only for now. I'll PM you with my contact info. Canada is no issue, just adds a little extra for shipping.
Old 07-23-20, 11:19 AM
  #181
I’m a little Surly
Quoted: 699 Post(s)
Originally Posted by AlanKHG
belated followup but you'd be a good candidate to be a US importer of this stem
https://www.schindelhauerbikes.com/e...ries/Stem.html
I saw that stem and needed to get one.
It looks so much better sitting on the small head tube and looks almost like a quill on steroids. I agree someone needs to try figure out who builds these then import them into the states.
Likes For Germany_chris:
Old 08-06-20, 11:26 AM
  #182
joejack951's Avatar
Sneak peak Thursday:
Lower headset cups, polished, anodized, and etched.
Weight-weenie-esque aluminum cones.
Assembly should be in full swing in the next week or two. Happy to field any questions in the meantime.
Old 08-06-20, 01:06 PM
  #183
Brain17's Avatar
Here’s my money!!
will you go through amazon again or will you let us know how or where to purchase? I’m still at newb status so I cannot DM you at this time to order directly.
Brain17 is offline
Old 08-06-20, 02:38 PM
  #184
joejack951's Avatar
Yes, provided that Amazon continues to process orders efficiently as they have been as of late I plan to restock their warehouses. I do need to sort out the listing so that both color options appear on the same page still.
If you can't DM/PM me and want to order now (silver units still available) or just want to avoid Amazon, email me at joe at jjpne dot com
Old 08-15-20, 05:50 PM
  #185
Quoted: 7 Post(s)
Liked 8 Times in 6 Posts
Hooray! Im glad to see both colors being re-stocked. Sitting on my pennies until the amazon store has them again.
kkleine is offline
Old 08-17-20, 07:28 AM
  #186
joejack951's Avatar
As noted previously, Amazon will lag behind on availability for a good few weeks. If you are ready to buy, send me an email at the address above and I’ll set you up to purchase through Paypal.
I’m taking delivery of all the CNC components this afternoon so with any luck I’ll be shipping the first headsets by mid-week.
Old 08-17-20, 02:43 PM
  #187
Quoted: 7 Post(s)
emailed
kkleine is offline
Old 08-18-20, 06:28 PM
  #188
Liked 4 Times in 4 Posts
preaching to the converted
Inni upgrade to my 1989 Trek 1500.
Flieswowings is offline
Likes For Flieswowings:
Old 09-10-20, 01:15 AM
  #189
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times in 160 Posts
Okay, i've got to deck my trek out with my carbon wheelset and do a photoshoot sometime! That setup is wild though. Those wheels and those pedals? Huh.
When things go live on amazon again, I'll have to drop a review. Bike has been on my kickr for a bit but it's performed flawlessly outdoors as well. I'm likely going to use that bike more outdoors as the cooler weather sets in say october ish so it'll get a fair amount more use outdoors.
ridethecliche is offline
Old 09-10-20, 08:29 AM
  #190
This looks great!
daseighty is offline
Old 09-11-20, 06:08 AM
  #191
I have a pair of clipless I ride too but I also live in the city so I opt to push flat pedals because I've have a lot of "close encounters" and more than one love tap from cars. I just find it to be safer.
Old 09-11-20, 06:43 AM
  #192
This is genius and the best I've seen. Need to grab a couple.
LucaG is offline
Old 09-11-20, 10:17 AM
  #193
Quoted: 378 Post(s)
Liked 1,410 Times in 910 Posts
A question for Joe or Jack:
I'm having trouble with slippage of stems on the steerer.
One can surmise the high end finish may be partially culpritave?
I did not have any carbon paste.
My other ones have some scarring when I grabbed them with channel-locks, etc.
This seems to have them well locked in, but the new one, actually installed per instructions, is clean, shiny, and the stem pivots.
No doubt you have a solution.
Gracias, still, as I'm digging these every ride.... except the one...
RobbieTunes is offline
Old 09-11-20, 02:45 PM
  #194
joejack951's Avatar
First, let me say that I am humbled by the enthusiastic response to this product lately. Not much more than a year ago I considered letting it die a slow death. *I* was enthusiastic about it and it had a small but vocal group of cheerleaders since the beginning, but the product wasn't getting the traction I expected/wanted/needed it to get to continue investing my time in it. Well, things have changed! And of course it comes at a time when I'm busier than ever and while nearly everything was right on this latest batch of parts, there just had to be one QC issue thrown into the mix to slow me down. That has been sorted and headsets are beginning to roll off the production line.
Likes For joejack951:
Old 09-11-20, 02:46 PM
  #195
joejack951's Avatar
I'll be in touch. Both black and silver headsets are now available. I'm happy to ship worldwide.
Old 09-11-20, 02:54 PM
  #196
joejack951's Avatar
Me: Joe 'Jack' is the first half of my very common last name. I forget who first called me JoeJack but it stuck and I like it better than Shoeless.
Interesting issue. How exactly are you getting slipping? Are the bars turning on the steerer while riding or are they just easy to pivot about the steerer in general? I hate to blame the 'other guy' but given how part of my assembly protocol involves clamping a stem to the steerer and applying a hefty amount of torque to it via the stem, I'm inclined to believe the issue is not the finish on the steerer.
The stem you are using is part of an integrated handlebar/stem, correct? Do you, or someone you know, have digital calipers to get a sense of the inner diameter of the stem clamp? I'm guessing it's off by quite a bit, or out of round, or both. Regardless, I'd start with carbon paste then perhaps move on to additional shims to tighten the fit. I can hook you up with some 0.1mm stainless to go down the latter path.
I'm just going quietly ignore the channel lock comment and act like I didn't hear that. If anyone gets into a situation where they need to apply torque to the headset during install or bearing preload, please clamp a stem onto the steerer for that purpose. Thanks in advance!
Old 09-11-20, 08:33 PM
  #197
Quoted: 378 Post(s)
The stem is tight, but can still move on the steerer.
Stem 1, I tightened to where the threads were damaged.
I replaced it, can not get it to seize, even overtorqued.
I am not using an integrated stem/bar. Standard stem.
I know you don’t like the channel-lock thing, but it does scar up the steerer so the stem clamps on well....
Old 09-11-20, 09:19 PM
  #198
joejack951's Avatar
Which stem?
Old 09-12-20, 12:18 AM
  #199
Excellent :-)
LucaG is offline
Old 09-12-20, 08:37 AM
  #200
Quoted: 378 Post(s)
Which stem?
1 Ritchey WCS
1 Toseak (Mao's)
Neither are tight enough to use a stem to torque down the headset on installation.
I kind of like the scarring idea as a gripper.
