Mandatory disk brakes
Quoted: 4806 Post(s)
Liked 3,932 Times
I have 5 bikes that stop really well with rim brakes. All the bikes are keepers. Three bikes are fix gears with good rear brakes (where discs would work very poorly if at all - Edit: you could make a disc bike with a fix gear work but the easy ability to change cogs and gear ratios wouldn't happen). Front wheels are interchangeable between all. I have The geared bikes have at least two rear wheels each (so I can have different gears and tires mounted). That's a lot to replace if I decided to to discs.
I have zero desire to go to a whole new system that won't make me one second faster, just maybe more predictably slower.
Ben
Ben
Randomhead
Liked 3,700 Times
Mandatory is not the right word, but rim brake bikes are definitely on the decline in all sectors. Probably until they get everyone converted to disc, and the marketers decide to go back to rim brakes because they are lighter.
Bikes: 2000 Trek 720 Multitrack (plus)
Quoted: 48 Post(s)
Liked 3,932 Times
Ben
Quoted: 2976 Post(s)
Liked 1,182 Times
Ben
Ben
Liked 1,182 Times
Yup. But static weight is different than dynamic weight.
Easily offset with carbon bars, carbon seatpost and a lighter seat. Or even a lighter wheelset.
And if you think that 1.5 lb difference will make a difference in speed...it's the motor...not the bike.
Non omnino gravis
Liked 3,932 Times
But. as I said above, the marketers probably won't be on to this for about another 5 years.
Ben
Quoted: 48 Post(s)
The FX 3 disc costs $120 more and the offsets you suggest are not free. Also the non disk FX 3 can be lightened the same way also so it's still 1.5 lbs. That's 1.5 lbs you have to pull up a hill regardless of your motor. It's also another 1.5 lbs you have to lift onto a car rack or carry up stairs to an apartment. If you don't need the benefit why bother, especially if it's mechanical disc brakes that may not function better and was only added to check off a marketing bullet list item. That's whats nice about the FX3, you can choose, and as the orginal poster noted, that choice is starting to disappear.
I'm happy with my rim brakes, but I bought my Colnago basically knowing it's sort of an antique already or a modern classic if you will, what with its rim brakes, dropouts, and max 25mm tire clearance (not to mention 5800 with the release of 7000 happening right now). I wanted a good, solid road bike. My hybrid has rim brakes (V-brakes, which are garbage) and drop-outs as well.
But let's be real, next time around for either bike it'll be discs and thru-axles, and I'm ok with that. I'm sure discs have their own adjustment/alignment problems, etc., but rim brakes have always sort of sucked to really dial in well, especially V-brakes.
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
Not difficult at all. I order my replacement pads from Amazon for $10-$15.
So order pads ahead of time before they wear out so you have replacements on hand. It's not that difficult. I have 2 sets of back up pads at all times.
I don't disagree with you, but rim brakes will soon be a thing of the past except for low end bikes from the big box stores. You either lead, follow or fall behind.
The demand is changing the inventory for most lbs, the only catch is if your bicycle is not of the higher food chain, then you will be left trying other stores. Although, most bicycles can be 'upgraded' to accept the more readily available configuration. Doing the upgrade* would then make local parts easier to source... as well as give more support from those that will know how to service a frequently used configuration...
From the above being applied; There are other ways to use pads that don't directly swap in, but you'd have to have resources or just creativity & basic bench tooling to resolve the compatibility issue.
This is common with most parts, & not just limited to bicycle parts. Too many times I'd go to a hardware store, home improvement store, automotive store, even a grocery store & experience the "Sorry we don't have that" lol.
Having a brake block crumble in a time of need was not a fun experience. Reason it crumbled is because of it dry rotting. There's a shelf life for most things, & for rubber it is not going to out due the resin. Only battle will be remembering where you last put the pads, but that is not a fault of the brake part, just the person.
Relying on other's to do a basic service is ok to a point, but if given the choice to do it myself or have it possibly done wrong by someone else, no hesitation would exist to just do it myself.
Quoted: 792 Post(s)
Liked 1,494 Times
"Compulsory?"
Or they find a way to start pushing ceramic disks down our throats because, as you just said, they are lighter still! Then brake-by-wire will probably come along, and then self-uprighting, self-riding bicycles that don't need to be pedaled or steered by the rider...
Quoted: 792 Post(s)
Liked 1,494 Times
Bikes: 2013 Trek 4.7 Flatbar Madone, 2018 Giant Roam 2
Quoted: 103 Post(s)
But did you look at that Kestrel flat bar road bike I was saying? Comes with full carbon frame, 105/Ultegra drivetrain and rim brakes? LOL I'm just kidding.
I have a flat bar Madone with Ultegra rim brakes and a Giant Roam with hydraulic disc brakes. I love the bite on the Ultegra rim brakes, but I also love the ease of use and modulation with the hydraulic disc brakes. Both have their pros and cons and both will work with bikes. Just get out and ride folks.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Look, gentlemen, the key issue here, at least for me, is to not complicate things. It's awesome to have the latest and greatest, but it's just as awesome to keep things simple, because simplicity really is at the heart of the joy of cycling. Having a need to stock up on application-specific brake pads when general-purpose brake blocks are available at the nearest shop for a fraction of the cost isn't exactly my idea of joy, and neither is having to "upgrade" a system that has specific requirements so as to have it accept more generally available components when there wasn't anything wrong with the older, tried-and-true system to begin with. And neither should I - or anyone, for that matter - feel the need to conform just because the Campagnolos, Shimanos, and SRAMs of the the world say we should.
Index shifting was initially met with significant resistance (and still is in some circles). It absolutely complicates things. Shimano shifters aren't compatible with SRAM derailers and SRAM shifters aren't compatible with Campy derailers and, what...Shimano has two different cable pull ratios and shifters for 10 speed? What? Index shifting can be tremendously complicated, and goes against the notion of Keeping It Simple. Who needs a ratcheting shifter? Real men shift with friction, right? Right?
Obviously, I say and ask some of that in jest. The primary difference between index shifting and disc brakes, as I see it, is time. We're only a few years into the widespread adoption of disc brakes on consumer level bikes. But index shifting has been in place on consumer level bikes since the late 1980s, about 30 years ago. Both index shifting and disc brakes complicate the bike, but they also offer benefits to most cyclists.
Obviously, everything is relative. Disc brakes are quickly becoming commonplace and they'll continue to increase in popularity and acceptance of general cyclists. One can "blame" any number of things: evil marketers, race fan boys, the "gotta have it" crowd. In the end, though, those who don't like them and never will are eventually going to have to accept the fact that they'll need to ride older bikes, or buy bikes that can be converted to rim brakes (if your bike has a brake bridge and a fork crown, you can use caliper rim brakes).
Just like those who still prefer to friction shift must do. THEY haven't been able to buy a new bike in decades!
Quoted: 576 Post(s)
Liked 1,003 Times
Road cycling is very traditionalist. I can see high end calipers being offered for way longer. Custom builders will always exist in this segment.
Look at mountain bikes. The writing was on the wall with AMP, Diacompe, and Hope in the early 90s. By mid 2000s Vs were relegated to low end bikes where they still remain. Even cantilevers have a niche market still. Suspension frame design and less traditional baggage made the transition rather effortless. There was a year or two of front disc/rear V but its all disc now.
Hybrids have even less tradition than MTBs and the novice buyers are more dazzled by shiny disc brakes than lighter v brakes, even if the cheap discs suck.
Liked 1,182 Times
Quoted: 792 Post(s)
Liked 1,494 Times
Anything gets complicated as soon as it starts to need special tools and planning ahead. I'm not - or at least not trying to - overthink this. I'm merely pointing out the fact that I can no longer get what I want off the rack. If I want my next bike to have a metal frame and fork and rim brakes, my only options might well be to either go custom or buy used.
Which is to say that the cycling world - or, the bicycle-buying aspect of it, that is - has become all but unrecognizable to me. Marketers still succeed in pushing the "cool" factor of carbon fiber and disk brakes while manufacturers make a killing, only for it all to become obsolete a season or two later, and the sales cycle starts all over again. I'm seriously thinking about rebuilding my old gas pipe Raleigh to make it my daily rider again.
Liked 762 Times
That was 30 years ago. There are still some who prefer friction, but the technology has really matured and I think most riders have come to appreciate the benefits, and feel that the benefits outweigh the drawbacks. Disc brakes haven't been mainstream for 30 years. I wouldn't even say they've been mainstream for even 10 years. The technology, as good as it is today, is still pretty new, and standards are still sort of finding themselves (IS vs. post mount, 6 bolt vs. centerlock, etc). It'll continue to mature and more folks will continue to move over into the camp that believes the advantages of disc brakes outweigh the drawbacks.
I believe you're right, that you can't get exactly what you want off the rack anymore. That era is coming to an end. A guy who likes friction shifting hasn't been able to buy a rack bike for decades. Folks who prefer things that are out of the mainstream have always found ways to build what they want, and that's part of what makes cycling a cool hobby. There are a LOT of riders in the C&V forum (Classic & Vintage) who build their own gas pipe bikes with friction shifting and rim brakes. There's a TON of help out there on this.
One of my best riding bikes is a 1969 Peugeot. It doesn't have disc brakes (but I did put an index shifter on it). It's from a different era and that's a big part of what makes it enjoyable. My two daily riders are modern aluminum bikes (a hybrid and a mountain bike), but I'm firmly in the "steel is real" crowd, and two of my favorites in my collection are classic steel bikes. I love riding them.
Quoted: 792 Post(s)
Liked 1,494 Times
"Aluminum frame, aluminum fork, and rim brakes" is quickly becoming a nearly impossible combination these days. As many must've noticed, since about late 2016, every manufacturer have been converting their entire high(er)-end road and hybrid ranges to disk brakes and carbon forks. I bought my 7.3FX in early 2016 because it was the only one in the FX range to have had an alloy fork to match the aluminum frame; the 7.2> models had steel forks and the 7.4< models had carbon forks. When I sold the 7.3 in late 2017, Trek no longer even had an FX with an aluminum fork in the range; the FX 2 had a steel fork and the FX 3 came with carbon. Ordering an alloy fork to replace the carbon one on my 2014 7.6 was a bit of a hassle.
It was much easier to buy a bike 30 years ago. Back then, I don't remember anyone giving a **** whether you rode a Raleigh or a Peugeot or whether you ran Shimano or Weinmann. It used to be like "hey, you got your bike? Good. Let's haul ass." Now you got all the fanboys and the marketeers with the loud CG music and the 23-year-old mountain bikers looking at you sideways and talking down to you because you're old and fat. It didn't used to be like this. [soapbox mode off.]
Quoted: 576 Post(s)
Liked 1,003 Times
You can ignore the marketing kool aid and just enjoy whatever aspect of cycling you enjoy the most.
Chombi1
Classic & Vintage
99
12-08-17 09:40 PM
