Adult coloring books have got nothing on this
Quoted: 981 Post(s)
Liked 1,844 Times
Hey Andy be sure to do your homework. there are many types of respirator cartridges, with different use cases. find the right one, and remember they dont last forever. I treat the chemical cartridges as one use only for safety (if you store then in a air tight bag, you should be good for one paint job). You DO NOT want the 2K clear hardening inside your lungs!
And yes, the 2k clear has those nasty isocyanates. Don't want to mess with that stuff! I'm personally going to chance spraying the frame I have outdoors under an awning rather than inside since I don't want to bother my uncle about using his booth.
-Gregory
Likes For Kilroy1988:
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 674 Post(s)
Liked 994 Times
I am working on stepping up my rattle can paint skillz as well. My most recent endeavor being a couple months ago. Bought a 60cm/biggest Specialized Tricross Sport Triple near the end of last year and after some component/setup testing went well, that was the green light needed to paint it and put gratuitously fancy parts on it. The aluminum frame had been stripped--pretty darn well I might add--by the previous previous owner, and looked dingy. I had plans to do a Cannondale-esque super buffing job, or at the very least, a masochistic multi-step wet sand effort, but the aluminum was having none of it. So paint it was. Picked up some "Pixie Dust" from the brand Color Shot. Lots of fun names that I appreciated, from a company that, through can shape and features, marketing/branding, and naming, is definitely not aimed at, well, guys.
I erroneously thought Pixie Dust was a pearlescent white, but it was actually pearlescent clear. I wanted a whimsical color full of sparkles to contrast with the Ultra Serious Fast Biker parts I was going to put on it and apparently failed at eyesight and reading comprehension. With the frame and fork all ready to go... Grabbed some matte black high-temp enamel paint from the shop/garage and said to myself, "Self, sparkly black will have to do." So I sprayed the black, then the Pixie Dust, and the frame turned forest green.... What is the world anymore??? Anyway, not all, or any, was lost! I had MASSIVE sparkles going on, and I knew that dark green with tan wall tires and black rims would look epic (from a prior build for someone else). I used 2k Clear's little brother, 1K Clear. Not as durable, but also not as nasty. Decals from eBay (definitely NOT Velocals in quality nor price) and away I went to build! Could I have stood to sand between coats, as well as cut and buff (or similar) the clear coat? Very much so. But, I wanted to build the darn thing and this is going to be a gravelly adventure bike.
Started with this:
Puzzled at the green, but hyped for the sparkly green and matching frame and fork (and stem, like all those fancy custom bikes get).
To this end result: 20.8 lbs of Um, Did You Put A Specialized "S" On That Carbon Bontrager XXX Stem???
48mm tires try in vain to fill the vast space between the fork blades.
Is this the cool guy bike pose? Anyway, all that to say, Andy, is that with more patience and planning than me, you can make it look actually legit, not fading in and out of smooth gloss and textured semi gloss finishing (tried hard to get the stuff to lay down well, but I painted it outside, 25 feet from where this photo was taken). Looking forward to seeing it progress! I also like the added braze-ons. I would have done the same.
Started with this:
Likes For georges1:
Bikes: Yes
Quoted: 3236 Post(s)
Liked 3,883 Times
I'm surprised how much texture Chapman had in his paint at this stage. I've had that with the bikes I've painted, but I've learned how to clean it up with wet sanding. I thought it was just a symptom of my poor technique. I don't know anything about what he was doing, but the finished product ended up perfect, as all his work does.
My Bikes
My Bikes
Likes For Andy_K:
Bikes: Yes
Liked 3,883 Times
For isocyanate, no cartridges are good enough, you need a supplied-air hood, with air pumped in from somewhere distant, outside the spray booth. The stuff is highly carcinogenic. You can't even take the lid off the can without your hood on and air pump running.
That's the advice for pros, though maybe as a hobbyist doing just one frame, you could get away with organic vapor cartridges. Not HEPA, which are only for particulates. HEPA over an organic vapor cartridge can be a good idea though.
Check the mask fit by covering the air inlets and trying to breathe in. If any air is getting in around the edges of the mask, no bueno. Beards are not allowed.
Plus, I'd have to shave my beard!
My Bikes
My Bikes
Bikes: Yes
Liked 3,883 Times
It looks great in your pictures, but I know first hand the person who paints a bike is always painfully aware of the gap between how a bike looks in pictures and the flaws they know are there.
My Bikes
My Bikes
Likes For Andy_K:
Bikes: Yes
Liked 3,883 Times
My Bikes
My Bikes
Bikes: Yes
Liked 3,883 Times
I like automotive paints because I like shinny finishes. I also sometimes use Rustoleum. I don't remember if I have actually used automotive 2k Clear Coat over Rustoleum, however, I have used it over Koolest Kolors single part enamel and it worked well. I think if you let the Rustoleum or enamel paint dry enough, I waited about a week and then use the 2k clear coat you should be good. Of course, you will need a compressor and gun. I don't know if this is something that you have or would consider.
As for specific clear coat brands, everyone has their own opinions on these. I have been using a value brand that I get from my local auto supply shop. The results are good for the price. If you go to paint forums some people like my choice and some do not. The other issue is the gun. You can do a good job with a Harbor Freight gun. I have one. It doesn't put out the volume of paint, a wide spray pattern or atomize as good as the pro guns, but for a cheap gun on a bicycle frame where you don't need a wide pattern, it does good. I also have a more expensive gun, but it is not one of those high priced pro guns. I am not a pro, or even close. I paint in my driveway.
As you probably know already @Andy_K , prep work is the most important factor and be patient. If you go this route, spray on a cardboard box to get used to whatever gun you use and get it set up.
For this project my original idea was to see just how far I can push the limits of standard rattle can paint, and I think I'm going to stick with that. I can always strip it down and try again in a few years if I'm not happy with the results. That's one of the great things about doing your own work, I guess. The cost of materials is well within the budget of what I'd spend just to learn something new.
My Bikes
My Bikes
Bikes: Bicycles? Yup.
Quoted: 488 Post(s)
Liked 1,623 Times
Originally Posted by Andy_K;22933517It's a [url=https://www.harborfreight.com/p95-maintenance-free-dual-cartridge-respirator-large-67727.html
Harbor Freight cheapie[/url], but they describe it as a cartridge respirator.
When the cartridges are used up, you'll get breakthrough and know it right away, you can smell/taste it and it's time to stop and step away.
Likes For BTinNYC:
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 540 Post(s)
Liked 1,034 Times
Likes For Pompiere:
Quoted: 813 Post(s)
Liked 1,034 Times
This is the base coat. There is no clear coat over it so it looks a little textured. That will all smooth out with clear coat. I am showing the bottom bracket so that you can see how the paint looks at different angles. Good stuff this HOK paint in a can.
I do like my clear coats though. Tough and glossy. There are also 2k clear coat aerosol cans like Eastwood were there is a separate container within the can that contains the activator. This gets mixed inside the can right before you are ready to paint. There are others that also make 2k clear coats in aerosol cans. Spray Max is another. I have not used either one though.
Likes For Velo Mule:
Master Parts Rearranger
Quoted: 1557 Post(s)
Liked 2,029 Times
If memory serves, forest green was the factory color for the Tricross in some years. Maybe the bike just really wanted to be green.
Likes For RiddleOfSteel:
Liked 2,029 Times
That is the color I have been looking for to paint my FW Evans, but I was for green paints, not black. I had used Rustoleum Cobalt Blue Metallic to paint my Fuji with good results. Their website shows the same paint in forest green, so I was hoping to use it again, but I can't find it anywhere. I see that Walmart has Pixie Dust on the shelf, so I will pick some up and try it over a few different undercoat colors to see which one I like best.
Bikes: Yes
Liked 3,883 Times
If my patience holds out, it will be a few weeks before I have an update with the bike in color. In the meantime, I painted a wood sample to see the color. I think it'll come out pretty close to how I envisioned it.
My Bikes
My Bikes
Likes For Andy_K:
Bikes: Yes
Liked 3,883 Times
I tried to wait until after my vacation to break out the Cobalt Blue, but I couldn't quite do it. I sanded the final layer of primer on the fork on Thursday, and Friday night I gave a few coats of color. My justification is that it will let me see if there's a difference between only waiting six days versus waiting two weeks, plus I'll be able to experiment with the clear coat sooner if I decide to do so. The reality is, I just couldn't wait.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 981 Post(s)
Liked 1,844 Times
Looks good, Andy! Once I fix the dropout on my Vincitore I'm still not sure which color I'll go with, but it might be similar to the original blue (which appears to be just slightly darker than yours). Will you be doing any contrasting colors on the head or seat tube?
-Gregory
-Gregory
Bikes: Yes
Liked 3,883 Times
I've got some chrome tape. I wonder if I could pull off a chrome barber pole? Probably too much.
I would have really liked to do something like Mercian's Electric Pearl Blue, but that's beyond what I can do with a rattle can. But one of the reasons I chose to attempt DIY paint instead of powder coating (the other option that was within my current budget) is that the spray paint will be easy to strip off for a better finish later. Besides just being a fun learning project, this will let me enjoy the bike for a few years without doing any harm to it.
My Bikes
My Bikes
Quoted: 540 Post(s)
Liked 1,034 Times
Yeah, that Pixie Dust, after my experience, is put in the "Your results may vary" bucket. I'd be interested to see what your experimentation results in. I went quite liberal on the Pixie Dust application. The first finer dust of it was basically barely sparkling black. That would have been neat, but I'm glad I went full Unikitty on it. I still need a bike in a candy fuchsia at some point, because I am crazy, but that will have to wait.
Rustoleum Forest Green on the left, Dark Forest Green on the right. Rustoleum Almond is for contrast on the head tube and seat tube.
Likes For Pompiere:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 992 Post(s)
Liked 656 Times
I wonder for masking of such complexity, if anyone has tried masking fluid that you paint on. I recall modelers using something called "Magic Mask". I see Amazon for instance has various brands.
Regardless, that is very complex masking.
I've tried a few different kinds. For one project I used green Frog Tape, which I had on hand from having used it for painting walls in the house. It's good for masking the trim on walls. It left a lot of residue on the bike project I used it with, but other than that I think it was OK. For my previous project I decided to try something different. I got 3M ScotchBlue™ Ultra Sharp Lines tape (#2098). This stuff kind of plastic and a bit tougher than the Frog Tape. It tears off the roll easily, but stretches a bit. I find that for relatively simple lines it's a great choice. I used it on the fork crown pictured below on the 1979 Centurion Elite that I painted last year and was very happy with it for that project. For the Vincitore I'm working on now, I couldn't get it to cut cleanly enough for the tight curves and fine points of the lugs, even with a very sharp blade. When I was out getting some other supplies for the current project, I came across 3M Automotive Performance Masking Tape. The packaging said it was good for curved surfaces, so I thought I'd give it a try. You see from the pictures above that it worked well for conforming to the lug edges. It was mostly easy to cut, but on the fine points I kept getting a few fibers that didn't want to separate and essentially had to be scraped away from what I was leaving, sometimes pulling a bit off that I would have preferred to leave. I think for my case that's OK since I am masking chrome that I want to be bare in the end. I'll be able to polish off any minor overspray. If you were trying to mask a color to be kept it would be more of a problem. I haven't found a tape that is perfect for that.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Bikes: Yes
Liked 3,883 Times
I was thinking about this last night and I think I may need to do the masking again because I don't think I'll want to apply decals and clear coat until I've seen how my lug masking looks after paint. It seems likely that some touch up will be needed.
My Bikes
My Bikes
Likes For Andy_K:
aka: Dr. Cannondale
Quoted: 2159 Post(s)
Liked 3,453 Times
Try Pro-Line Liquid Mask- can be applied with a brush or airbrush- and a #11 X-Acto blade. Trick is to paint well over the lug and onto the tube itself, then use the blade tip along the edge. Then remove the excess dried masking from the non-lug area- it just peels off. Available from R/C hobby supply places like Horizon.
And patience. Lots of patience.
Likes For rccardr:
www.theheadbadge.com
Quoted: 2429 Post(s)
Liked 4,421 Times
At this point I don't even have a working theory on how to pick one that would work well for masking chrome. If anyone has experience and can recommend a brand I would be interested.
-Kurt
Likes For cudak888:
Bikes: Yes
Liked 3,883 Times
I love it when a plan comes together!
I still need to do a bit of clean up around the masking, but this is about the go in the storage space above my garage to bake for a couple of weeks, and I wanted to strip off the masking to get an idea whether the project was going to be successful or not. I'm over the moon happy with it. And I think it comes pretty close to @RiddleOfSteel's mock up.
Now it just needs a couple of weeks to let off gas, then I'll apply the decals and clear coat. So far, so good!
My Bikes
My Bikes
Likes For Andy_K:
Liked 2,029 Times
Looks great!
Señor Member
Quoted: 1499 Post(s)
Liked 1,102 Times
Andy K - Nicely done. Will the paint on the chrome rub off?
I came to the thread late. I once attempted a DIY 2-K clear over a frame. Used a 3M mask with cartridges and sprayed outdoors. Bottom line was that I was not impressed with the results, and I suspect that I have neither the equipment, nor the space to do this properly and safely. After reading through this, I was wondering if anyone had priced a professional doing a good 2K clear over a frame they had painted themself? If not excessive, I am thinking that reducing the risk of self harm and improving the result might be worth it. As I look about 2 years out, I see that I may have 3-4 frames that I expect to complete painting myself and am thinking that if I have a small batch to send to a painter, I might be able to bring the price per unit down a bit.
