Freezing Drizzle / Rain Safe to Commute In?
Old 12-12-18, 05:53 PM
lmike6453's Avatar
Quoted: 123 Post(s)
I want to commute in tomorrow morning but it's going to start a freezing drizzle 30 mins before I leave in 31F temperature.
I have 2.4 inch tires on my ebike (no knobs) and travel at about 20-22mph on a mixture of back roads and bike trail for 8 miles.
https://www.schwalbetires.com/bike_t...s/super-moto-x
Should I ride in or drive in?
lmike6453 is offline
Old 12-12-18, 05:57 PM
Quoted: 119 Post(s)
Liked 94 Times in 64 Posts
With studded tires, I'd ride in. I would not drive. Is coming in late or telecommuting an option?
PaulH is offline
Old 12-12-18, 06:13 PM
medic75's Avatar
Bikes: '19 Trek Stache 5, '17 DB Hannjo Trail, '09 Scott CR1 Pro, Schwinn Central commuter, '16 DB El Oso
Quoted: 108 Post(s)
Liked 57 Times in 29 Posts
With the freezing rain and the chance of it freezing into a sheet of ice on the roads, I wouldn't ride without studded tires. This doesn't even consider the cars that could be sliding around on the potential ice. As much as you enjoy the ride, safety comes first.
medic75 is offline
Old 12-12-18, 07:13 PM
Bikes: Sekine 1979 ten speed racer
Quoted: 1481 Post(s)
Liked 639 Times in 437 Posts
Ditto to the previous recommendations for riding in wirh studded tires.
However, as also stated, it does depend of the car traffic. You'd be ok on the trails and bike paths but getting to and from them on the backroads, how fast would the cars be? If they are backed up bumper to bumper, I wouldn't mind riding on the road and filtering between them. But if there's any chance of them moving as fast as you or worse, faster than you, ride as far from them as possible and keep a lookout for anybody who looks like he might be losing control.
Daniel4 is offline
Old 12-12-18, 07:35 PM
lmike6453's Avatar
Quoted: 123 Post(s)
Interesting to ride in on studded tires instead of driving in. Makes sense.
I like to be in on time vs telecommuting unless driving isn't safe either.
It's more like back streets...I get on a main road (35 mph limit) that probably won't be icy for the cars for less than 0.4 miles, then back streets with only a sole car here and there for 1 mile, paved trails most of the way, and last mile is neighborhood streets with moderate traffic 25mph limit.
Old 12-12-18, 09:04 PM
mcours2006's Avatar
Bikes: ...a few.
Quoted: 2014 Post(s)
Liked 410 Times in 236 Posts
Nah. Risk is too great for having a fall with freezing rain without studded tires. At some on your route you're going to have to go on surface that has ice on it; you might not be able to tell where it is.
mcours2006 is offline
Old 12-12-18, 11:11 PM
BobbyG's Avatar
Quoted: 1368 Post(s)
Liked 1,695 Times in 835 Posts
with the freezing rain and the chance of it freezing into a sheet of ice on the roads, i wouldn't ride without studded tires. This doesn't even consider the cars that could be sliding around on the potential ice. As much as you enjoy the ride, safety comes first.
+1
BobbyG is offline
Old 12-13-18, 10:46 AM
Bikes: 1 for road & 1 for gravel
Quoted: 154 Post(s)
Liked 37 Times in 29 Posts
Nope. Not a chance. Freezing rain is nothing to brag about. Better safe than sorry in these situations.
crazyravr is offline
Old 12-13-18, 10:51 AM
Quoted: 2633 Post(s)
Liked 1,985 Times in 1,242 Posts
Freezing rain in my town leads to what I call "bumper car" traffic. If I've got to play that game, I want a couple thousand pounds of steel on my side.
Maybe the drivers in your area are better equipped and more experienced in low traction conditions.
pdlamb is offline
Old 12-13-18, 05:03 PM
I rode in to work one morning after it had rained ice-rain overnight. When my co-worker saw me come in he asked wasn't it slippery? I replied " Only when I get off."
Since that day, I wear spikes under my boots.
Check if those back roads are salted or sanded.
Get studded tires installed before you ride.
Daniel4 is offline
Old 12-13-18, 05:19 PM
bobwysiwyg's Avatar
Quoted: 941 Post(s)
Liked 319 Times in 189 Posts
One would think so, but despite snow being inevitable here, every year, and I mean e-v-e-r-y year, first storm reflects amnesia on the part of 90% of drivers.
bobwysiwyg is offline
Old 12-13-18, 05:44 PM
Quoted: 590 Post(s)
Liked 445 Times in 260 Posts
+1 for studs. Schwalbe Marathon Winter will allow you to ride on an ice rink.
Freezing rain collecting and freezing on your eyewear is even more of an issue, that isn't easily solved.
Riveting is offline
Old 12-13-18, 07:10 PM
lmike6453's Avatar
Quoted: 123 Post(s)
Thanks for the responses, more questions...
How do you manage swapping tires just for one day of snow / ice when the next is warmer and its melted?
Do you swap just the tire or have an entire different wheel set?
Or leave studded on even though its not needed that day and burn the tread up?
Old 12-13-18, 08:27 PM
Quoted: 119 Post(s)
I take the bike to the shop and put on the studs in mid-December. In March, I take it in to put the summer tires back on. The studs and the rubber wear at the same rate, and that rate is about the same as that for the summer tires. The tread does not burn up.
PaulH is offline
Old 12-13-18, 09:03 PM
medic75's Avatar
Quoted: 108 Post(s)
The studded tires go on the bike at the first sign of ice in the fall & stay on until spring. The studs on quality tires are carbide & will not significantly wear on dry tarmac. You can raise & lower the air pressure to adjust how the studs will contact the tarmac.
medic75 is offline
Old 12-13-18, 10:01 PM
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times in 252 Posts
I switch between Continental TContact Winter and Nokian many-spikes. Continental are transitional tires so penalty for keeping them on too long is limited. In the other direction I am just unnecessarily slow. In any case, I may swap every few days and at times put a studded just in front. I do the swapping in 2 sweeps. At first I wash the tires and let them stand to dry. After they more or less dried out I change the tires. I use Koolstop/Soma tire levers for taking the tires off and help myself with one or other tire bead jack to put the tires on. Altogether it is a 6min (taking off/washing) + 16min (swapping/putting wheels on) operation. It is not a big deal when you weave it in-between other operations, but in the morning I must of course plan for this not to get late.
2_i is offline
Old 12-14-18, 04:55 AM
robert schlatte's Avatar
Bikes: Soma Saga, 1980 Schwinn Voyageur 11.8, New Albion Privateer
Quoted: 76 Post(s)
Liked 9 Times in 7 Posts
Have you not ever ridden on ice or icy streets? It can be absolutely treacherous and nearly impossible to keep the bike upright. You definitely need to check the road surface periodically. Put your foot down to check traction. If it is sheet ice, forget about it unless you have studs. Also, don't even think about going 20 to 22 mph, try more like 10 to 12 or slower. Everyone has different acceptable levels acceptable risk. Experience is the best teacher.
robert schlatte is offline
Old 12-14-18, 06:29 AM
mcours2006's Avatar
Bikes: ...a few.
To give an example of what studs can do for you I rode in this morning, arriving not 20 minutes ago. The road was wet but the temperature was -1*C and I'm sure most of the road was not icy because of the layer of salt on it but I'm sure there were sections where it was icy. The conditions are right for that type of black ice. But with my Marathon studs I couldn't tell and there was no incident.
The route includes a short park trail as well and that was icy. Without studs I wouldn't not have been able to ride through it.
As for swapping tires/wheels, I have two sets of wheels for the bike. It takes two minutes to swap with a minor brake adjustment. But when in doubt always go with studs.
Old 12-14-18, 07:37 AM
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times in 228 Posts
I don't think you need studs in these conditions. In my area, we get freezing rain like you'd get snow - you have to watch out for shadows, slick looking patches (that could be frozen), and take exaggerated care on any maneuvers, but at 31° the freezing rain is mostly liquid on the roads and probably melts off in the direct sunlight.
wphamilton is offline
Old 12-14-18, 08:06 AM
CliffordK's Avatar
Quoted: 18435 Post(s)
Liked 4,549 Times in 3,380 Posts
Last spring I mounted a pair of Michelin Protek Cross Max tires. No freezing rain, but I hit partly melted slush in a few places, and the tires seemed to be very sure footed. I was impressed.
However, in general, I have the ability to stay home for ice and snow, and avoid it as much as possible.
CliffordK is offline
Old 12-14-18, 10:12 AM
Quoted: 840 Post(s)
At some point I had 3 sets of tires I used across winter, expensive hand-made wheels, SON hub and custom cassette, so swapping wheels was out of question. Now I am down to 2 sets and a regular cassette, so may start thinking about different wheel sets, funds permitting.
2_i is offline
Old 12-14-18, 11:26 AM
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times in 169 Posts
I have one bike that has studs in it all the time. I can decide if I want studs at the last minute. If there is black ice don't try to ride without studs.
Cold hard flat glare ice is impossible to ride very far without falling without studs. But hard flat ice is the best surface for studded tires to grab. I don't believe that anyone with experience on glare ice would say you don't need studs. The biggest danger on ice if you are on studs, is cars without studs sliding around. Where I live studded tires on cars is illegal.
It's very hard to asses the chances of falling on some ice and some dry pavement, along your route. You have two choices. 1) wear out studded tires somewhat quickly. 2) Or possibly falling and getting hurt, or possibly falling in front of a car if on the road. I have plenty of off road, on lake, or bike path riding available to me. I do it for fun. I have annoyed a couple of skaters when I rode on an ice rink one day. Been using studs on ice on a bicycle since about 1990. Going back to the 1970's for studs on a motorcycle.
2manybikes is offline
Old 12-15-18, 05:23 AM
medic75's Avatar
Quoted: 108 Post(s)
I would love to agree with you, but depending on where the OP is in Pennsylvania, freezing rain is a little different. Under some conditions, freezing rain falls as rain,washing away any residual salt on the tarmac, and then freezes into a sheet of extremely slick ice with a layer of water on top. This is a condition where you have difficulty standing up on. This typically only lasts a couple of hours before the surface temperature rises or the road crews spread some salt. This is common when the ground is frozen and a warm front causes the precipitation to be liquid. While this is likely the worst case scenario, it is not an anomaly.
medic75 is offline
Old 12-15-18, 09:43 AM
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
I now have a dedicated winter bike with the studded tires on it. It's my short-haul shopping bike, so it doesn't have to be high performance. Winter riding involves two factors in my locale: Ice and salt. I'm not sure which is worse. The winter bike lets me hang up my nicer bikes during the salt season (or to take my good old time cleaning and maintaining them). It's a single speed with coaster hub, so there's only the bare minimum of stuff that needs to be protected and cleaned.
I don't mind riding the studs when there's no ice. The studs and tires seem to last a long time. At 8 miles per day, it would take me a few years to wear them out.
Gresp15C is offline
Old 12-15-18, 12:06 PM
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,359 Times in 865 Posts
I just grab the bike I left the studded tires on* , and where I live that may be a couple years...
I used to see the weather report, for the next day and change tires overnight ..
A harder rubber compound is used on studded tires , that helps retain the studs
*I don't own an E bike, owning 2 of those is probably not a plan.. Too far to pedal?
fietsbob is offline
