Home made Bottom Bracket Cup Tool - pin spanner
Old 09-13-08 | 01:00 PM
somegeek's Avatar
Harumph
Home made Bottom Bracket Cup Tool - pin spanner (pics)
Was going to purchase a pin spanning tool and figured I could make one. Took a 14" piece of 1/8" music wire and put it into my hand held drill and with the drill running, held each end against a file to taper the tips so they'd fit into my Campy BB cup. Next, I held the tips against some sandpaper to polish them. Bent 1/2" of each end to 90º and then put a bend in the middle.
Saved me a few $ to spend on other bike stuff.
You can pick this music wire up from your local True-Value hardware store or the like.
somegeek
somegeek is offline
Reply
Old 09-13-08 | 05:59 PM
I made one out of an old circlip tool I had lying around. It's a pliers-like handle with screw clamps on the end to hold various straight or right-angle heads to engage clips.
I just ground off the little pins; the body of the heads fits right into most BB spanner holes.
Bikewer is offline
Reply
Old 09-13-08 | 06:16 PM
Nice idea and nice photos!
Mondoman is offline
Reply
Old 09-13-08 | 06:27 PM
cab horn
20 Anniversary
Bikes: 1987 Bianchi Campione
Ok let's see this stand up to a sezied cup
operator is offline
Reply
Old 09-13-08 | 06:47 PM
somegeek's Avatar
Harumph
Heh... didn't say this was bullet proof.
somegeek is offline
Reply
Old 09-13-08 | 06:49 PM
cab horn
20 Anniversary
If you can engineer a tool that can withstand having a breaker bar put on it about 1M in length to break off sezied cup, i'll buy the first one you make
operator is offline
Reply
Old 09-13-08 | 07:06 PM
somegeek's Avatar
Harumph
Bet it'd be easy to make one that would utilize all six holes(or whatever your application) out of a piece of steel... given you have a plate of steel and maybe a drill press and a tap. Drill the seven holes in a metal plate and use 10.8 hardness screws which fit all six holes. With all six studs taking the force, they'd be less susceptible to break.
somegeek is offline
Reply
Old 09-13-08 | 07:39 PM
cab horn
20 Anniversary
Sharp.
There already is a tool like this out there. 6 pins with a threaded piece that threads it on the outer cup of the bb. The problem usualy is that the pins don't withstand the force needed to break the cup free.
operator is offline
Reply
Old 09-14-08 | 07:42 AM
This is the home-made version of Park Tool's "Hairpin" spanners made in various sizes for bottom bracket cups, Shimano and Campy auto-extractor crank retainer rings and Ashtabula cranks. They are not bullet proof or expected to be.
If the cup is REALLY frozen in place, you remove the lock ring and apply a pipe wrench to the exposed threads. Then you buy a new cup.
HillRider is offline
Reply
Old 09-14-08 | 08:10 AM
Or.... Get yourself a punch or drift pin that will fit into one of the spanner holes, and use a hammer. With luck, you can even use the cup again.
Bikewer is offline
Reply
Old 09-14-08 | 04:40 PM
OR remove the fixed cup, axles and bearings. Then get a bolt that just fits through the axle hole put a nut (maybe a lockwasher too) on the other side and use an impact gun to remove the cup. The impact wrench will tighten the nut (well, hold it with a wrench) and the vibration/impact will release the cup.
IF that fails, heat the cup (not the bottom bracket shell), let cool and repeat.
dcullen is offline
Reply
Old 09-14-08 | 05:47 PM
cab horn
20 Anniversary
So what happens when you can't remove the fixed cup either?
operator is offline
Reply
Old 09-14-08 | 05:55 PM
Luddite
Bikes: Univega Gran Turismo, Cannondale Synapse, Bianchi Aquiletta Folder
If you can remove a stuck fixed cup with any tool that uses those 6 little pinholes, I'll eat my hat. Use the Sheldon Brown bolt method on a stuck fixed cup. The OP has a nifty device for holding the left side while it's being tightened.
Squeazel is offline
Reply
Old 09-14-08 | 10:16 PM
JanMM's Avatar
rebmeM roineS
20 Anniversary
What kind of musical instrument uses 1/8" music wire? Never seen a guitar string that robust.
JanMM is offline
Reply
Old 09-14-08 | 10:26 PM
somegeek's Avatar
Harumph
AKA Piano Wire - https://en.wikipedia.org/wiki/Piano_wire
somegeek is offline
Reply
Old 09-15-08 | 07:50 AM
JanMM's Avatar
rebmeM roineS
20 Anniversary
Would 1/8" be the lowest string on a grand piano? I need to take a look at a piano. Can't find any strings on my Casio keyboard!
JanMM is offline
Reply
Old 10-10-08 | 04:22 PM
mx_599's Avatar
Lost in the Black Hills
now you should dip the end in that "plastikote" stuff or whatever it is called.
mx
mx_599 is offline
Reply
Old 10-10-08 | 07:00 PM
Grand Bois's Avatar
It's called Plasti Dip, but I don't know why you'd want to dip the ends in it. That would be like dipping the tips of your screwdrivers
Grand Bois is offline
Reply
Old 10-10-08 | 07:05 PM
mx_599's Avatar
thanks
i meant the one "u" end
mx
mx_599 is offline
Reply
Old 10-11-08 | 10:23 AM
lymbzero's Avatar
otherwiseordinary
Still nice,
I like it!
lymbzero is offline
Reply
Old 10-12-08 | 02:25 AM
mtnwkr's Avatar
Pro status
Bikes: many
Nice! I've been using the tips on a pair of needle nosed pliers...
mtnwkr is offline
Reply
Old 04-21-11 | 09:53 AM
instructions's Avatar
15 Anniversary
Bikes: 1990's Miele, 1980's Woodrup, Bridgestone 400, and customs
you know I do that too? I find it 1.) stiffer than a spanner and 2.) easier to control.
I take a pair of needle nose pliers and put the ends on the opposite side pins of the cup, then use an adjustable wrench secured to the pivot point of the pliers.
I find that I can get substantially more torque without slipping. I've been able to remove cups from rusted-out-behind-the-shed old bikes with that and a little triflow.
instructions is offline
Reply
Scratcher33
Bicycle Mechanics
3
08-26-18 10:31 PM
tonyfourdogs
Bicycle Mechanics
22
04-30-18 12:24 AM
rgvg
Bicycle Mechanics
21
12-17-17 07:51 PM
derekb
Bicycle Mechanics
5
08-02-16 08:44 AM
bikemore
Classic & Vintage
7
04-25-10 01:37 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
