Go Back  Bike Forums > Bike Forums > Framebuilders
Does this frame geometry make sense?
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
View Poll Results: Does this frame make sense?
Yes, it should be a fun inner-city commuter
6
75.00%
No, you're a moron
2
25.00%
Voters: 8. You may not vote on this poll
Old 04-07-09 | 09:40 PM
I played around a little in BikeCAD this afternoon, after getting my frame fitting results back. I'm trying to shoehorn my 6'5", 94cm inseam body around a fast commuter frame to fit 700x38c tires+fenders (and an EBB).
Does this geometry look reasonable? It's 72.5 head angle, 63.5 C-C seat, 63 C-C top. Using a Dimension cross fork (400mm A2C, 45mm rake) the trail ends up being about 62.5mm, the Jones -2.4, and the front projection .067.
This is my first frame design, so I really don't know what I'm doing. Any advice would be welcome!
File Type: png
File Type: txt
antonyfhilliard is offline
Reply
Old 04-08-09 | 09:19 AM
JohnDThompson's Avatar
Old fart
Titanium Club Membership
20 Anniversary
Community Builder
Looks ok to me!
Braze 'er up and tell us how it rides!
JohnDThompson is offline
Reply
Old 04-08-09 | 09:52 AM
cbchess's Avatar
Map maker
Bikes: Ventana El Ciclon, Walt Works 29er, Specialized Enduro (fixed up for my son).
Front looks to be a bit steep in the head angle and might be on the twitchy side. That is just my personal preference, I like a slacker head angle.
cbchess is offline
Reply
Old 04-08-09 | 10:42 AM
Framebuilder
Looks good, should work fine. Although I think you'd be better balanced if the chainstays were a bit longer.
Live Wire is offline
Reply
Old 04-08-09 | 09:36 PM
arshak's Avatar
'Cross and Road nut
Bikes: '85 Atala, 87 De Rosa Track bike, TT Funny bike (24inch front wheel), Ritchey Cross bike, K2 Razorback, Bridgestone, Atherton, Cannondale, Tsunami, Custom Ti Bike,
I would go with 71.5 or 71.7 degree head tube angle as this is going to be a BIG frame and with correspondingly longer chain stays in the back, my 2 cents worth
arshak is offline
Reply
Old 04-09-09 | 01:02 PM
Thanks all, I appreciate the advice. I'll add 10mm to the chainstays, since I'll be riding it semi-upright most of the time and will probably have lots of weight on my butt.
What I really want to get is the 'carvy' feel in making tight turns in small city streets at 20km/h. Sort of like a criterium, but with less pedaling in the turns. That's why I put in the 72.5 head angle. Fingers crossed!
Reply
Old 04-09-09 | 01:15 PM
Framebuilder
That's what I prefer too- stick w/the steeper HA, you'll be glad you did.
Reply
Old 04-14-09 | 05:29 AM
Thylacine's Avatar
Industry Maven
20 Anniversary
Bikes: Thylacines...only Thylacines.
My Mods in RED
I'm assuming this is a steel frame....
Frame Angles
*Headangle = 72.5∞
*Seatangle = 72.5∞ (71.5 if using a straight post)
Major Lengths
Wheelbase = 1088.5549 mm
*Seat tube length (c-t) = 690.0 mm
Seat tube length (c-c) = 638.6374 mm
Top tube length (effective) = 632.68585 mm (Might be a tad long for a commuter)
Top tube length (c-c) = 630.00476 mm
*Head tube length = 200.0 mm (215)
*Bottom bracket height = 271.5 mm
Bottom bracket drop = 77.5 mm (70)
*Chainstay length = 440.0 mm
*Front Center = 660.0 mm
Fork and Headset Specs
*Fork offset = 45.0 mm (48-50mm would be better with 72/72.5 HTA)
*Fork length = 400.0 mm (might be a tad short)
This is a rigid fork
*Lower stack height = 11.0 mm
Stability Info
Trail = 62.855465 mm
Jones stability criterion = -2.4148805
Relative front projection = 0.06759858
Tube Diameters
*Seat tube diameter = 34.9 mm (31.8)
*Top tube diameter = 31.8 mm
*Head tube diameter = 38.1 mm (36)
*Down tube diameter = 50.8 mm (38.1)
Seatstay Info
*Seatstay diameter = 22.2 mm (16mm if using caliper brakes)
Direct distance from rear axle to center of seatstay at seat tube junction = 566.4608 mm
Sideways angle of seatstay = 6.1623745∞
Seatstays are straight
*Distance from top of seat tube to center of seatstay = 40.0 mm
*Location of center of seatstay at seat tube junction (0∞ = rear of seat tube, 90∞ = side of seat tube) = 45.0
Bottom Bracket Info
*Bottom bracket length = 68.0 mm
*Bottom bracket diameter = 57.2 mm (38.1)
Chainstay angle relative to horizontal = 10.356807
Seatstay angle relative to horizontal = 67.59641
Welding Clearance Info
*Head tube extension above top edge of top tube = 8.0 mm (10mm)
*Head tube extension below bottom edge of down tube = 10.0 mm (15mm)
Gap between bottom of top tube and top of down tube at head tube junction = 90.58825 mm
*Seat tube extension above top edge of top tube = 40.0 mm (20)
Extension of outer face of BB from side edge of chainstay = 3.7928886 mm
Gap between inside edges of chainstays at BB junction = 15.585777 mm
My 2c
Thylacine is offline
Reply
Old 04-24-09 | 08:33 PM
Thanks Thylacine. I've shortened the seat tube extension above the top tube to 30mm. The 77.5 BB drop and 57mm shell is because I'm using an eccentric - I figure I'll lose about 7-8mm from rotating the eccentric upwards to tighten the chain.
As for more fork rake... well, it's steel, I'll just have to test-ride it and bend it if necessary.
Reply
Old 06-02-09 | 09:36 AM
Followup: The frame rides great, it's just as carvy as I hoped for. I did get a bit of pedal strike when riding home drunk, and the top tube is definitely 1cm too long, but them's the breaks. Thank you for your advice.
Reply
Old 06-08-09 | 08:57 AM
cbchess's Avatar
Map maker
How about some pictures!?!
cbchess is offline
Reply
Old 06-09-09 | 02:27 PM
As you wish! (it's a bit ugly, I built it up with cheap used parts from the local bike co-ops)
File Type: jpg
File Type: jpg
File Type: jpg
Reply
Old 06-15-09 | 06:51 AM
cbchess's Avatar
Map maker
nice!
where did you order such a custom frame? how much?
cbchess is offline
Reply
Old 04-23-12 | 02:46 PM
Three years later on my XACD chinese Ti frame:
* I specced the BB too low, top tube too long (as I mentioned before)
* XACD specced the tire clearance symmetrical on top and sides. This resulted in unneccessarily bent chainstays (didn't need 1cm side clearance)
* Cable guides not ideally placed - rear brake cable guide too close to caliper, Rohloff chainstay guide doesn't secure cable around bends (could be solved be straightening chainstay)
* Top tube too high - straight top tubes are too 1970s. Should have sloped the top tube 10-15 degrees, and gotten a taller seatpost.
* Fork was too short. I replaced it with a 410mm carbon fork which works great.
Other than that, it's been good!
Reply
e30jean
Bicycle Mechanics
11
06-19-16 09:45 PM
indian101
Framebuilders
11
06-16-15 10:40 PM
adam_mac84
Framebuilders
7
03-28-14 03:18 PM
jemsurvey
Road Cycling
2
01-13-10 05:53 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
