are disc bakes supposed to squeak
master of bottom licks
Quoted: 111 Post(s)
Mine don't even squeal in the wet but then I clean the rotors and pads every few weeks if the weather has been wet and road grime starts coating the bike. I use a clean shop towel wetted with acetone to clean rotor and pad surfaces... it removes contaminants that denatured alcohol can't touch.
Bikes: To many to list.
Some times yes, sometimes no. I've had high end brakes that squeaked, and cheap ones that didn't. Add in water and dust, and you might or might not get squeaking.
DancesWithSUVs
Quoted: 7 Post(s)
The only way for a rotor to get warped is to take a hit from something. And it shouldn't have taken long to tweak it back. I've used an adjustable wrench to true a rotor that took a hit at a polo match and it only took about a minute. Again,for some reason many mechanics don't seem to know what to do with discs.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
DancesWithSUVs
Quoted: 7 Post(s)
this is how to kep them from squeeking and will spin silently with no energy loss.
1. loosen the two screws on the rotor thing a bit
2. squeeze the brake of whichever brake is making the noise
3. while squeezing said brake, screw the screws back in
4. it should be silent now
Bikes: Felt nine flow
Quoted: 662 Post(s)
Liked 7 Times
o mine there is 2 bolts on the caliper and the caliper can be adjusted by loosening them to make sure the pads hit the router flush.mine are adjusted real good. i am not sure how close the pads should be to rotor so i adjusted em to they touched and backed em back a bit. i hope i was able to make my self clear i suck at explaining my self
Curmudgeon
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
[JOKE]
…sounds like they might need need oiling!
[/JOKE]
- Wil
[/JOKE]
- Wil
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
Oooooooops! Guess that's something they forgot to mention in the specs.
Best QUIET wet weather performance is still XTR parallel push V-brakes. But they were discontinued because of all the percieved hype about disc brakes.
Bikes: Nothing amazing... cheap old 21 speed mtb
Having both v and disc brakes I agree. Even cheap vs with coolstops are almost as good as discs and are effective yet quiet in the rain. Not as good as discs, but pretty close. Of course if your wheel gets out of true and you need to ride home discs win... been there done that.
Quoted: 223 Post(s)
I've got BB5s on my paratrooper, they only squeal (and really not that much) if I really apply them hard (and suddenly) when they're wet. If I'm gonna slow down I usually just apply em a little to get most of the water off and then use as I normally would, just to avoid some squeaking. I'm pretty happy running only disc brakes (this is one of the older ones that had front disc only originally) and would continue to use them in the future.
DancesWithSUVs
Quoted: 7 Post(s)
Yep,that's how it's done.
Silvercivic27
Road Cycling
5
05-27-17 07:57 PM
