ISO and for trade thread part 5
#4977
Stop reading my posts!
Quoted: 1453 Post(s)
Liked 1,078 Times
unworthy1,
Ok, completed some measurements and arrived at an estimate of bolt shaft length.
Flats of the bolt shaft is 5mm thick
Round of the bolt shaft is 6mm thick
Domed nut is 9mm long
see photo for next...
Cable hole is 2mm
Derailleur section the bolt must pass through is 6mm
So assuming the bolt shaft needs at least 4mm to catch in the nut, then
estimated bolt shaft length would be 12mm.
Sound about right?
Cable hole is 2mm
Sound about right?
#4978
4.6692016090
Bikes: yes
Quoted: 59 Post(s)
Liked 81 Times
I will follow up with PM.
#4979
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 439 Times
The bolt I have has the total length of 13.8mm, threaded part 6mm. Flat to flat part is 4.9mm, round to round is 5.8mm. Cable hole is between 1.5 and 2mm.
#4980
I have some Simplex mountain bike thumb shifters if anyone wants to swap for something. I haven't sent anything Stateside for years and I think since Canada Customs has increased the PITA factor wanting you to fill out their forms "online" beforehand.
Could use a 9mm Ritchey "Skraxle" for a front wheel. The wheel is useless without it.
#4981
Edumacator
Quoted: 2514 Post(s)
Liked 3,284 Times
Simplex thumbies are very cool little items. You are correct that there is definitely more effort needed to ship from here to you, but it is really the surprising cost.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
#4982
Update - I knew what I had was French but was wrong on the Simplex branding. These are SACHS-Huret.
#4983
Edumacator
Liked 3,284 Times
#4984
Quoted: 1116 Post(s)
Liked 1,340 Times
Lock that stores inside handlebar?
I once had a lock that stored inside the handlebar, it was a plastic-sheathed cable that slipped inside the handlebar, doubled, terminating in the lock-and-bar-plug arrangement. When stored all you saw was the rubber plug.
I was unable to find a picture on the net, but found this instead; more or less the same idea but keyed (=better, the one I had was a combination):
I know neither of these would be much problem for anyone with determination, but to prevent an opportunistic walkaway they'll do; the real plus is nothing need to be attached to the bike, or even seen to be attached.
So I'd like either version...
EDIT - found a (bad) pic of the one I had:
#4985
Close!
These are they (on their way already{!} to a BF member for a French build up);
#4986
Not lost wanderer.
Quoted: 890 Post(s)
Liked 1,020 Times
Decent 25.4 or 25.6 seat post. Something like an Sakae or SR.
need it for my market bike. I think I have one in my stash in the States but no one to look.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
#4987
Quoted: 359 Post(s)
Liked 582 Times
Iso: 7900
Old enough to fit on a neo-retro....
ISO:
7900 calipers
7900 FD braze-on or 31.8
7900 crankset (maybe)
Weinmann 730 calipers (Varsity build!)
Cinelli Volare (suede) nearly new (
Have:
NOS 1055 group to include wheels (DT)
Assorted stuff, much of it no longer C&V.
Ultegra and 105 10-s and 11-s stuff
SRAM X.9 RD's (2)
Lots of rings
5500 crankset double
5600 STI's
Coupla modern wheelsets, maybe 4
ISO:
7900 calipers
Have:
SRAM X.9 RD's (2)
Lots of rings
5600 STI's
#4988
ISO: Trek 560
I am looking for a 1984 Trek 560 road bike or frame in size 56-60. Please let me know if you have one or have seen one that’s available. Thank you.
#4989
Liked 1,340 Times
Need serrated headset washer/hanger combo
One of these:
to go here - in place of the black serrated washer and that kludge of a brake cable hanger can then be retired:
#4990
Quoted: 215 Post(s)
Liked 439 Times
Oh my, I'd love one of those! Didn't even know anyone made French standard brake cable hangers. On the bicycle I use centre pull brakes on, I could afford adding another milimeter or two to the headset stack height, so went with Weinmann (I think) cable hanger (the model with cable adjuster, not the one with QR) which was stamped in a sheet of metal (around 1-2mm thick). But the solution above is simply awesome.
#4991
Liked 1,340 Times
And sometimes a 25mm hole with a flat.
The Zeus hanger is a close second - similar construction but no slot and a riveted ferrule.
#4992
Edumacator
Liked 3,284 Times
Who was just looking for one of those...? @Andy_K perhaps. Or maybe he was looking for a newer one but ended up using the old?
#4993
Bikes: Yes
Quoted: 3254 Post(s)
Liked 3,947 Times
@oneclick I have the piece you’re looking for. Send me a PM.
My Bikes
My Bikes
#4994
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 166 Post(s)
Liked 102 Times
I like your kludge.
#4995
Stronglite Crank Set
If anyone's looking for one, I ran across this. I don't know and haven't done business with the seller, and have no financial interests here.
https://www.ebay.com/itm/175345224908
Seller located in US, asking cost around $53.50 with S/H. Dunno if the seller ships internationally or not, or if they might accept a lower offer (the listing doesn't have a "Make Offer" option, but that's not always definitive).
Item appears well-worn, is 170mm, and is a 5-arm, non-fluted design. Both crankarms appear to be marked "J5". Chainrings specified as 52/40, 122mm BCD. Chainrings and bolts included; bolts have some rust.
Have no idea if it's worth the cost, but if someone needs this exact crankset at least it's an option.
#4996
Quoted: 948 Post(s)
Liked 3,033 Times
Let's see: Weinmann is well-represented. There's one set of drilled levers with Weinmann-branded gum hoods, one low-end set with safety levers (I don't remember if they had hoods), two sets with Carlton hoods, one has slotted levers and one, solid. I think I had 2 sets of Mafac levers, one just went on my '71 PX-10 with some fresh red half hoods from a fellow forum member. There's a set of the aforementioned Exages, a set of Superbes with gum Dia-Compe hoods, and a set of Shimano 600s with Cane Creek hoods. I have no idea where some of these came from.
#4997
Edumacator
Liked 3,284 Times
by the way, all well stocked hoarding places need at least one random 600 set of levers and a pair of Superbe levers. It is expected that they should in no way, shape of form have the partner calipers...I have 2 sets of each I believe.
#4998
Quoted: 948 Post(s)
Liked 3,033 Times
i have a similar issue. They sort of just appear and who knows which they came in. I put a bunch of the where the heck did they come from brakes in the FS forum, and especially had a unique assortment of Modolo and Gran Compe stuffing.
#4999
Quoted: 293 Post(s)
Liked 354 Times
ISO a cable stop / barrel adjuster unit for a Modolo Corsa brake caliper. Looks pretty much like the pic below, though there are variations. I'm not picky as long as the shoe fits. The calipers are up for trade too if anyone wants 'em...
#5000
https://www.ebay.com/itm/294499609452
Not by Ritchey, but it's a 9mm thru axle. Dunno if it would work for your specific application or not.
Don't know the seller, haven't done business with them, and have no commercial interests in play here.
Edited to add: Also ran across a listing for a DT Swiss 9x100mm thru axle at about 2x the cost of the above. PM me if you want that info.
