For the love of English 3 speeds...
Old 06-19-19, 03:41 PM
  #20676
3speedslow's Avatar
Bikes: A few
Quoted: 1942 Post(s)
Liked 1,073 Times in 637 Posts
Originally Posted by BigChief
Those circlips that hold the cog on the driver are easy to remove. It's getting them back on that's hard for me. I don't even have a good technique to pass along. It's one of those things I just fight with until I win.
Felt like the day was going my way so changed out the 15T for a 17. Easy indeed to get off, getting on is a two thumb hard press job but it’s back together.
3speedslow is offline
Old 06-19-19, 03:47 PM
  #20677
3speedslow's Avatar
Bikes: A few
Question for the learned: when I pulled the shifter rod, it was covered in black gunk. Poked a plastic stir stick down there and pulled out some really think muck. The hub has been shifting fine and ticking along but... would it be good to fill the hub with some kerosene or other such fluids and drain the swamp in there before the wheel goes back into action?
Fresh oil used afterwards of course!
Old 06-19-19, 04:16 PM
  #20678
Quoted: 457 Post(s)
Liked 462 Times in 270 Posts
Originally Posted by Ballenxj
I hope somebody here picks this up! Looks like a 23" frame as well.
Whats the deal with the 23" frames? Just fewer of them around?
I'd pull the whole cartridge out but don't disassemble it, you can roll it around in some kero and get it nice and clean the screw it back in.
You can just clamp the outer flange of the drive side of the hub in a bench vice and spin the cartridge out, I've only done 3, but that technique worked for all of them.
jackbombay is offline
Old 06-19-19, 04:20 PM
  #20679
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times in 23 Posts
All BB parts shiny and free of wear. I found chunks of old grease and a petrified wasp but no sock.
Amateurs! I hope you've got a nice sock picked out to put in there
arty dave is offline
Old 06-19-19, 05:08 PM
  #20680
Quoted: 515 Post(s)
Liked 167 Times in 116 Posts
There seem to be fewer of them for sale. The 23" frame is, as I read, the adult size for us taller people, and it seems most people are keeping theirs.
Ballenxj is offline
Old 06-19-19, 05:11 PM
  #20681
BigChief's Avatar
Quoted: 1299 Post(s)
Liked 103 Times in 85 Posts
Sure, you can flush it out. Anything that dissolves grease would be fine. Then add some oil. The only thing about that is it takes so long to drain that you spend weeks cleaning off your rim. I think, in the long run, it's less work to disassemble and clean the hub. That also allows you to pack the wheel bearings with a longer lasting marine grease. Not only that, its fun. It's not a difficult or frustrating job like stuck cotters.
BigChief is offline
Old 06-19-19, 05:19 PM
  #20682
Quoted: 515 Post(s)
It's not?
Ballenxj is offline
Old 06-19-19, 05:47 PM
  #20683
3speedslow's Avatar
Bikes: A few
@BigChief
Thanks for the info! I have time to clean it out. I have to save up for the spoke party now! Oh well, at least I will have SS with washers. The rim on it now will not be the one I am using so it can be as messy as it wants to.
I’m not that cool for a sock stunt.
Old 06-19-19, 06:13 PM
  #20684
usarnie1's Avatar
Bikes: 1936 Raleigh Sports Tourists, 1952 Raleigh, 1957 Raleigh, 1963 Raleigh Dawn Tourist, 1953 Hercules Tourist, 1953 Hercules Royal Prince, 1953 Hercules Windsor, 1958 Bianchi Sport & 1960 Bianchi Sport
Quoted: 25 Post(s)
Liked 9 Times in 4 Posts
More Bling added to my Hercules
Today, I changed my Miller headlight for a 1910 McKeelite that I modified with 24 LEDs. Additionally, I added the Hercules Royal Prince stickers that I purchased from RedBubble.com. The big items I added are the Tourbon tan pannier bags and tan triangle bag.
I applied the rubbing compound to the bike. It did improve the looks. However, I was not able to restore the paint to its' original lusture.
usarnie1 is offline
Likes For usarnie1:
Old 06-19-19, 06:21 PM
  #20685
usarnie1's Avatar
Quoted: 25 Post(s)
I forgot to mention that I ordered the Schwalbe creme colored tires. Additionally, I plan to change the handlebars for simular ones that have a 2"to 3" further reach out toward me.
usarnie1 is offline
Old 06-19-19, 08:41 PM
  #20686
BigChief's Avatar
Looking good! Compounding works better on some finishes than others. Depends on how deep the oxidation goes. Here's a mudguard that needed extensive work. Compound, polish and wax worked very well on this paint as you can see on the un-repaired area. Clear coat can also be used to add gloss.
BigChief is offline
Old 06-19-19, 08:42 PM
  #20687
Hello fellow 3 speeders. Last week I found and purchased a 1953 Hercules Royal Prince, that was only 12 miles away from my home. This is my number 3 of 1953 Hercules that I own. Basically, the bike had good bones, so I went all out on its' rejuvenation. Shown below are the before and after photos of the bike.
Many of the front fork bearings were missing, the front tire and tube had a blow out, the front axel bearing races were pitted, the saddle was made in Taiwon, the hand grips were USA made, The chain had 2 links that were frozen, the rear clamp for the chain guard was missing, one of the pedals dust caps was missing, the kick stand was missing and the complete front brake was missing. Since these early 1950s Hercules are so rare, I had to have it!
I put on new Schwalbe tires/tubes, used original Hercules tan saddle, new matching tan hand grips, used Brooks tan leather tool bag, complete early Hercules front brakes, nice used front axel and bearing races, period correct Midland repainted carrying rack, Miller generator light kit with a stem mounted bracket, NOS Hercules pedals, Raleigh logo kick stand, new indicator chain and its' anchor and all new cables. Coming soon will be reproduction Hercules chainguard sticker, tan pannier bags and matching triangle bag to mount in-between the V portion of the frame.
After2
Awesome. I'd love to add a 50s 3 speed to the stable.
reno rs is offline
Old 06-19-19, 09:32 PM
  #20688
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
Ad's gone now, but a rod brake Raleigh was probably a 28" wheel Tourist and those men's frames were 22" or 24".
thumpism is offline
Old 06-20-19, 03:49 AM
  #20689
BigChief's Avatar
You should! They are fun and actually practical utility bikes. As an old time 3 speeder my advise would be to hold out for the frame size that suits you best. The common light roadsters come in either 21" or 23". If you're over 5'10" or so, you'll want the more rare 23".
BigChief is offline
Old 06-20-19, 04:41 AM
  #20690
gster's Avatar
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 444 Times in 288 Posts
Little oil, drill, punch and repeat.
All nice and clean!
Still ready to do the job after 40 years!
Success! Fighting all the way but the cotter finally came out. All BB parts shiny and free of wear. I found chunks of old grease and a petrified wasp but no sock. The Teflon spray was helping it but new grease is what it needs.
The drill bit stayed mostly in the pin but towards the bottom drifted out into the crank. I can see a little divot out of the wall. Both openings are still round. I will be getting new pins, most likely from Mark.
I'm sorry that you didn't find a sock.
I was hoping another one would show up so I'd have a matching pair.
gster is offline
Old 06-20-19, 05:24 AM
  #20691
BigChief's Avatar
Now we know the Raleigh part number for a Twenty BB spindle is 21GC. Really odd that cotter snapped off the way it did. They are supposed to be a softer alloy. I see there's not much dome on the top. I wonder if this was the original 'R" cap cotter or an aftermarket. But even then, there was a lot of poorly thought out cost cutting going on at Raleigh in the 70s. Maybe the cotters from new weren't good quality.
BigChief is offline
Old 06-20-19, 05:34 AM
  #20692
gster's Avatar
They are a bit of a mystery.
The cotters on the '30 Hercules came out as if they'd been installed the week before .
gster is offline
Old 06-20-19, 07:00 AM
  #20693
Quoted: 331 Post(s)
Liked 332 Times in 185 Posts
Stuck pin removal of the last rrsort
Slacken off the nut a few turns, offer up the frame horizontal and place in the vice. Place one jaw of the vice against the crank opposite the stuck pin, place a socket over the pin top so it clears the pin and presses on the crank body. Place the other jaw directly on the slackened cotter pin nut opposite and press the pin out.
Johno59 is offline
Likes For Johno59:
Old 06-20-19, 07:20 AM
  #20694
BigChief's Avatar
I've given some thought to this issue, but I still have more questions than answers. Even in this case, you can see from the picture that unlike aluminum stems and seat posts in steel frames, corrosion wasn't the cause. Even in the LBS where I worked, mechanics in the day would just hammer cotters in. For a long time, I guessed stuck cotters were just the result of being hammered in too hard. But now I wondering if perhaps the alloy they are made from is involved somehow. I've removed many cotters over the years. Probably not enough to be of any real statistical value, but enough to get an impression. I too have noticed that cotters from bikes from the 50s seem to pop out without much fuss and the only time I've had to resort to plan B was on later models. I have also noticed that the alloy of the old cotters...and Bike Smith cotters as well... looks different than more modern cotters. There's no finish on them. They're not very hard and are highly rust resistant. Just a thought.
BigChief is offline
Old 06-20-19, 08:20 AM
  #20695
3speedslow's Avatar
Bikes: A few
My feeble take: torquing on the crankside makes those a little more harder to drive out. Mine are of the nonR-nut variety. They were also driven in quite deep. The NDS cotter slide right out so I think it had something to do with the placement or torque on the pin. BTW, the tool used was the old Park cotter one and both sides had 2 days of soaking before the operation.
I so wanted to find a sock!
The part number on the crank spindle facing up was just PURE luck!
Old 06-20-19, 08:28 AM
  #20696
riverdrifter's Avatar
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 171 Post(s)
Liked 278 Times in 108 Posts
Reproduction sticker purchased from RedBuble.com
Fantastic bike!
riverdrifter is offline
Old 06-20-19, 08:33 AM
  #20697
Ged117's Avatar
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 470 Times in 192 Posts
The differences between the cotters from my '50 Superbe and those from the '79 Sports parts bike were immediately evident. The '50 cotters were clearly a quality product and came out as gster said, as if they had been installed a week before, when it in fact it had been nearly 70 years. The '79 cotters were crude by comparison - I would not reuse them. I would reuse the '50 ones though.
Ged117 is offline
Old 06-20-19, 09:55 AM
  #20698
Bikes: 1986 Schwinn World (2), 1972 Raleigh Twenty, 1968 Raleigh Sports, 1970 Robin Hood, Specialized Hardrock
Liked 3 Times in 2 Posts
My Raleigh Twenty and I are not having a good day.
I tried to service the bottom bracket on my Twenty a couple months ago and things did not go well either. I got the left side off, but wasn't able to on the right side. I sprayed it with PB Blaster and let it sit overnight (more than once), tried the vise/socket method, but no good. I gave up as I was afraid I'd damage the bike. For now I'll stick with a few drops of gear oil down the seat tube. I need to try the cut pipe trick and if that doesn't work, I'll drill it out to service the bottom bracket properly (next winter). I was able to get cotters from Harris Cyclery as I damaged the threads on the one I did get out and also wanted spares for my other 3 speeds.
RobbieAG is offline
Old 06-20-19, 10:45 AM
  #20699
3speedslow's Avatar
Bikes: A few
@RobbieAG
Here is what I found out after opening up the BB. The opening from the seat tube is tiny! If you are going to put oil down there to help keep it lubed, err on the side of plenty. I used a spray can of Teflon and 3 in 1 oil in healthy doses. Because there are no seals between the spindle and cups you might be able to sneak enough to the ball bearings through that route.
i am happy to have gotten the cotter out regardless. My LBS has been around over 40 yrs. they still have SA parts in their drawers and bins. I will see if the pins I come up with look decent or go talk to BikeSmith.
Old 06-20-19, 12:35 PM
  #20700
dweenk's Avatar
Quoted: 887 Post(s)
Liked 335 Times in 225 Posts
Some where on this forum there are instructions for making a cotter press from a Harbor Freight chain breaker. I made one a few years ago and have been successful with all of the extractions except one where the crank profile was so slim that there was not enough space to align with the pin.
dweenk is offline
