Addiction 2021.1
#4251
Quoted: 8287 Post(s)
Liked 9,064 Times
More adventures in snow-blower/small engines.
Recall the issue is that the engine starts RIGHT UP, runs for 30 seconds, then dies. Restart, runs 30 seconds again, then dies. Etc.
I took the housing off to expose the carburetor. Removed the bowl. Lots of flow of gas, so the idea that the gas line is not flowing properly is wrong. What a mess!
After I took off the bowl I did spray the needles and float and innards, best I could, with cleaner. I only had "throttle body" cleaner which I think is good enough.
I did not get a chance to test if this solved the problem, but will issue a report later today.
Does it have a manual choke? Have you tried choking it before it stalls?
Sometimes if there is a restriction in fuel flow through the main jet you can free it by choking the air when the thing is revving up. Wait until it is running at the highest rpm it will attain, then block all air with a piece of cardboard, the choke, or even your hand. The engine vacuum might pull crud out of where ever it is hiding.
#4252
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,930 Times
Many years (or pages) ago I suggested you spritz a little carb spray or other flammable liquid into the air horn to see if it would keep running. If it does, and you don't start a fire, then it's a fuel problem. If adding fuel this way doesn't affect it, then it may be an ignition problem.
It won't start at all.
Sad!
Before I say uncle and call the engine repair place, any suggestions?
p.s. It does have a manual choke, I have played with it both when stalling and now to get it started.
#4253
Quoted: 3361 Post(s)
Liked 3,638 Times
Sunbeam capture in progress:
Likes For abshipp:
#4254
Liked 3,638 Times
LPLO on desktop but not on mobile
#4255
VFL For Life
Bikes: Velo Volmobile
Quoted: 28639 Post(s)
Liked 1,858 Times
#4256
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12787 Post(s)
Liked 7,698 Times
Here's a recon lap. The rider's commentary amused me.
2021 UCI Cyclocross World Championships Ostend Course PreRide WIth Commentary - YouTube
#4257
Bikes: everywhere
Liked 7,698 Times
Likes For LesterOfPuppets:
#4258
Liked 9,064 Times
Can you take the spark plug out and see if it's wet?
#4259
VFL For Life
Liked 1,858 Times
#4260
Liked 9,064 Times
#4261
Administrator
Quoted: 11975 Post(s)
Liked 6,655 Times
Same. But my motivation was that I was getting OT.
#4262
VFL For Life
Liked 1,858 Times
DougRNS has what you need.
How does anyone train for it?
#4263
Liked 8,930 Times
#4264
Liked 9,064 Times
Likes For big john:
#4265
Quoted: 10238 Post(s)
Liked 5,189 Times
#4266
So it is
Quoted: 11407 Post(s)
Liked 4,761 Times
Likes For LAJ:
#4267
Administrator
Liked 6,655 Times
Um . . . before you book your trip . . . you have to realize he left out the sea-sickness part. A significant downer.
#4268
Mostly Harmless
Bikes: Have two wheels
Quoted: 13720 Post(s)
Liked 4,533 Times
#4269
Mostly Harmless
Liked 4,533 Times
#4270
Quoted: 20810 Post(s)
Liked 9,456 Times
I've never had an LPLO on mobile. I wonder if Bah Humbug has figured it out yet?
#4271
Bikes: everywhere
Liked 7,698 Times
If I ever Everested, it would be on a car-free course. That's all I gotta say.
Maybe a gravel Everesting would be nice.
#4272
Liked 8,930 Times
Done. Dry.
Tried again and not starting. I am pretty close to getting someone to fix it.
My mom called and asked how I am, I told her I am futzing with the snow blower. Her suggestion? Buy a new one.
wut
wut
#4273
Liked 9,456 Times
Just a PSA - Puck Moonen is
#4274
Liked 9,456 Times
For reals -
Likes For WhyFi:
#4275
Bikes: everywhere
Liked 7,698 Times
