For the love of English 3 speeds...
Bikes: Miele Latina, Worksman INB, Rapido Eska Folder, Raleigh Superbe, Raleigh Sprite, Soma Stanyan 650b, VeloSolex 3800, Raleigh Competition GS, CTC Supercycle, Raleigh Sports
Quoted: 25 Post(s)
Liked 9 Times
Re: My Failed Derailleur Project
I now know why 10 speeds have those big plastic discs on the rear wheel
and why sometimes they have a big chunk missing.
It's to stop the derailleur from smashing into the spokes...
I'd set the derailleur up with the SA throttle shifter.
Like a regular trigger it has a stop (indexed) and I thought
that the amount of travel would work the derailleur.
It didn't...
The shifter continued past the first stop pushing the derailleur
too far into the spokes.
I may re visit or wait for a proper vintage 2 cog derailleur
to show up.
It didn't...
to show up.
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 444 Times
Not my place to say however; maybe change the throttle shifter for a lever type friction shifter - the friction shifter would provide more of a visual reference as to where the derailleur "is" and be easier to trim. I expect its pretty hard to make small trim adjustments with the throttle shifter especially when going past the 3 speed detents. I know you will get it sorted out and look forward to a ride report. Cheers,
The problem is trying to marry a vintage British system with a vintage Japanese system.
I'll let this project lie fallow and re visit when I've thought about it a bit more.
The wheel I damaged wasn't from the A list anyway.
Quoted: 1858 Post(s)
Liked 664 Times
Re: My Failed Derailleur ProjectI now know why 10 speeds have those big plastic discs on the rear wheel
It didn't...
to show up.
It didn't...
to show up.
In modern bikes I don't think I've ever seen the big plastic (or metal) disks between the cassette and the spokes. We are supposed to adjust the derailleur travel limit screws to make sure the chain does not get driven into the spokes, and in my past 35 years I have not known them to fail, starting with my 2x6 1984 Trek 610. It was also the case 15 years earlier with my first 2x10 Falcon with a Campy Gran Sport. Back then we routinely had the LBS remove those (hence not looking like the dorks we were!), but I still didn't have any chain control faults.
You said (I think!) that you tried to depend on cable/shifter adjustments rather than derailleur travel limit screw setting. In this case a dork disk might help, but it's better just to set your screws correctly and check the derailleur for bending or flexing rather frequently. Or get a frame and derailleur that is higher quality, less flexible.
BTW, I'm not sure that claw is positioning that derailleur where it can shift your new sprockets correctly - it looks like the mech is pretty far behind the rear axle, and I expect that the free length of chain is too long for good shifting without a lot of overshift.
Quoted: 457 Post(s)
Liked 462 Times
I have an Raleigh Sports that I'd like to do a light resto mod on, getting rid of the steel rims is on the list, but new spokes and rims gets a bit spendy for a bike that won't get too much use, but I would be happy at $30 per rim if could reuse spokes.
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
Likes For paulb_in_bkln:
Quoted: 350 Post(s)
Liked 24 Times
Thanks Nlerner and JaccoW. It was a few days of indecision. I'm not terribly concerned with the bike not having French wheels. I'd like to keep the Mafac brakes, which I understand wouldn't have the required longer reach were I to convert the bike to 650b. The velocity dyad 700c is not cheap, but I plan to keep this one for the long haul as my beat-around four-season commuter. I'm attached to that '53 FW alloy hub - I think it'll look really awesome laced to new wheels. 40h certainly is disappearing, which is a shame since so many of the old Sturmey hubs are 40h. There is an FC close-ratio four speed on eBay right now for a lotta money...
Quoted: 350 Post(s)
Liked 24 Times
Quoted: 457 Post(s)
Liked 462 Times
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 471 Times
My experience with my Pug AW conversion was that with the stock antirotation washers I couldn't get the rear wheel to stay aligned in the frame. The washers sized for the larger slots on derailleur frames fixed that. Pick up a couple and you might save yourself some annoyance. Cheap at the price, IMO ($5 each, shipping included) on ebay.
BTW, my conversion was a bit simpler than yours. I already had a couple 700c CR18s sitting around from a few years ago that I'd bought for another project and never used and was able to dig up a 36-hole AW hub. It wasn't even something I'd planned; it just worked out.
I've finally managed to get the cable adjustment into spec, so now the Raleigh is running with all three gear options available. I took a 12 mile ride the other day along Ottawa's river paths to celebrate. Since my bike has the Cyclo 3-speed, it was fitted with a triple cog. The big'un is 21T, so that paired with the AG make the bike really enjoyable to ride on the flats or reasonable hills. I'm a little leery of going too hard on the pedals up hills, with the hub components nearing almost 70 years old. This morning I was heading into work on my Voyageur, and a guy passed me headed the other way riding a brand new Raleigh in the same colour as the one posted up thread. I also saw a Raleigh Laurentian parked downtown yesterday (Canadian only model - the hub said 1964).
Quoted: 350 Post(s)
Liked 24 Times
Liked 444 Times
Liked 444 Times
Speaking of 26" x 1-1/4" Endrick rims.....
The Canadian/British Mystery bike accepted an older pair of Kenda 27" x 1-3/8" (37-630) tires
As I've said before, I really like these club bikes.
Quoted: 360 Post(s)
Liked 471 Times
Hi folks,
I found a blue step through frame Sports locally. The hub is smooth on the top (no pattern on the shell like my spare '79 hub). I'm thinking of a reactivation and restore for my girlfriend since she wants an upright bike for comfy travel. The date on the hub is May 1972. It has the full chain ring, and silver painted front fork. Is there anything I should know about this year? I'd make a quick project of it this winter, rebuild the hub, service the bottom bracket, polish the chrome and paint. I'll post photos if / when I bring it back. It looks like this one, just with silver fork:
Liked 444 Times
Hi folks,
Silver forks? Could have been replaced?
Quoted: 360 Post(s)
Liked 471 Times
The seller turned out to be a Raleigh collector. I'm curious to see what else he has. The fork is original. He started taking the paint off with a scotch brite pad with a two tone repaint in mind. I'm going to prep it and then paint it a nice soft white to match the rear fender end. He's had it about ten years and never got around to it. Maybe this one will get a B67 when finished.
Liked 444 Times
Quoted: 1299 Post(s)
Liked 103 Times
Liked 444 Times
Candy apple red on a hot rod!
Here's a red '61 Superbe
And here's my blue '61
I think the white accent on the front tube indicates a Canadian bike.
Made in England for the Canadian market.
RC serial #
Hard to see, but a Superbe decal on the downtube.
This bike arrived in a bit of a state having been over-painted blue,
I started to strip it but decided to leave "as is"..
Chrome fork tips as well
Liked 444 Times
illustration.
When I got the bike, the front caliper was missing.
The rear caliper was the older style that only accepts the specific Raleigh cable.
Two newer ('70's) calipers were purchased from George.
The front brake required a very specific bevelled bushing to fit onto the front of
the unique forks.
Luckily it was intact on the original back caliper.....
Liked 103 Times
That's right
RC serial #
RC serial #
Liked 444 Times
From the 1954 Canadian catalogue. Courtesy the headbadge
We also had a specific Canadian "Laurentian" model.
I suppose they thought we liked white because of all the snow....
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
I had one of those!
Quoted: 360 Post(s)
Liked 471 Times
Liked 444 Times
That Laurentian is the exact same paint scheme as the bike I saw parked downtown here in Ottawa the other day. I snooped a bit to get a hub reading - 1964. It was clearly a well-loved daily driver, with panniers and basket, and worn looking panaracer col de la vie tires. The Rivendell Homer Hilsen parked nearby was also a big surprise. It was like a treat to see them hanging out with the moderns in the racks. It is really cool how often I see old three speeds around here - CCM, Raleigh, Eaton's Gliders, and I think a Philips once. They are usually weathered and casually maintained, but the hubs and wheels keep going.
Liked 444 Times
1958 Blue Superbe
This one just popped up on Kijiji today
$200.00 asking
$200.00 asking
