anyone riding a proper singlespeed/fixie...
...with chain tugs on bonafide horizontal fork ends and
NOT using any chain oil?
I'm not talking about a neglected chain, but one with the oil cleaned off.
I've been riding this setup on a few different bikes for years now and am pretty confused why anyone would want to dirty their bike up with oil and risk stains, dirt attraction, additional maintenance, etc. I know most of you guys are riding conversions or making do with horizontal drops and I can understand why track racers would benefit from a little extra slipperyness on a clean indoor track, but in my experience a straight chainline with the tension dialed in just right runs smoothly and efficiently with or without oil.
The reason I'm posting is because I'm so satisfied running oil free that I won't even consider buying new bikes with derailleurs, springloaded tensioners, or dropouts for fear of losing the magic. This is a problem because I've got the new bike bug and my selection of bikes with horizontal fork ends is rather limited.
Am I alone?
Perhaps I should mention that I did dip my chains in hot wax after I cleaned off all the oil, but that was years ago and as far as I can tell there's no remaining residue.
Am I alone?
partly metal, partly real
Bikes: Hummer H2
what a dumb op.
K2ProFlex baby!
From: My response would have been something along the lines of: "Does your bike have computer controlled suspension? Then shut your piehole, this baby is from the future!"
Bikes: to many to list
Am I alone?
Am I alone?
You see, their morals, their code...it's a bad joke, dropped at the first sign of trouble. They're only as good as the world allows them to be. I'll show you. When the chips are down, these...These "civilized" people...they'll eat each other. See, I'm not a monster. I'm just ahead of the curve
Got 'em on all my serious bikes, I don't use oil, and my chains and gears do not wear excessively (or at least not more than can be corrected with a tug nut)
It's so good that I'm afraid to drop real dough on anything else (like I said, I don't want to lose the oil free magic)
Bikes: 1975 Coppi Campionissimo, 1980 Raleigh Grand Sport, 1983 Trek 520, 1983 Ciocc, 1995 Trek 520
Why do you think that metal-on-metal, without oil, is a good idea? It seems ludicrously stupid to me, but I was only an engineer for 20 years before becoming a teacher, what do I know?
you realize that all new chains come with lubrication, right? Are you saying you never put on new chains? If not, then that just means you're running on the stock lubrication for awhile.
how about this -- buy a new chain, thoroughly degrease your chain with a strong degreaser to remove 100% of the stock lube, and install it. put some serious mileage on the chain and see how much you like it. I am willing to bet you'll either want to buy a new chain or want to lube it due to all the rust and squeaking.
Oh, boy ... another troll.
The OP must like really pointy chainring teeth.
( refer to sheldon brown site if you dont get the reference. )
K2ProFlex baby!
True bonafide proper track fork ends
Why do I NOT believe you? BTW, you wouldn't have to correct the problem as often if you used..... O-I-L! Shhhhhhh! Not to loud! The secret might get out!
I'm not saying that frequent or occasional oiling is never necessary for metal-on-metal interfaces, but apparently a precisely tensioned bicycle chain does not require it. Do you oil the metal-on-metal interface of the security chain you use to lock up your bike? Don't argue with me. Argue with my bicycles and their chains.
If you're not running unoiled chains on track ends with tug nuts then your input is not requested or appreciated.
Gee, lets see, turn the tug nut a few times or spend more money and make a dirt attracting mess? Which is a better way to correct the problem?
K2ProFlex baby!
Because it works, it's cheap, and it's clean. I'm currently an engineer and, let me tell you, only a fool uses a solution in search of a problem.
I'm saying I run my chains as clean as I can get them. I degrease them and whatever amount of lubrication remains I have found to be sufficient for efficient long lasting operation. No need to hate. I'm just asking if anyone else knows whether it works just as well with other setups or if there's something special about fully horizontal track ends with tug nuts.
Your way is the right way, how could I have been so wrong!
Maybe instead of oil I should use "Troll Away!"
Still kicking.
Bikes: Bike Count: Rising.
Hate to break it to you, that's not from a fork, forks don't have chain stays.
Appreciate the old bikes more than the new.
K2ProFlex baby!
^^^ your joking? right? Antways, here https://www.sheldonbrown.com/gloss_dr-z.html just in case your not.
Still kicking.
Bikes: Pake track, Soma DoubleCross, LeMond Etape, Maruishi RoadAce 303
And I'm Barrack Obama.
Explain how the tension in the chain causes a lack of need for oiling.
Either you are a moron, or you are being a jackass.
I'll oil my chain and let my chain, chainring, and cog last longer.
You are definitely not an engineer.
Gee, lets see, turn the tug nut a few times or spend more money and make a dirt attracting mess?[/QUOTE]
So you admit that not oiling your chain causes your drivetrain to wear out faster...
This thread is to seek out others that have observed the same lack of necessity of chain oiling and to inquire whether there are other configurations for which it works.
And stop trolling my thread, jackass, or I'll give you a wedgie with your tight little god damn hipster jeans.
By the way, you are wrong.
Really? It sure sounds like you ARE trying to convince us, and it's not working.
It looks like nobody else has observed this. Perhaps you are just wrong.
I'm only sensing one troll, and that's you. It seems that you can't take it when other people tell you that you are wrong.
Now, if you will kindly stop trolling for a fight then santa claus might leave you a real SS bike (instead of a dumb ass conversion with kludged up dropouts) so you can see what I'm talking about.
I swear, posting in this forum is like going back to kindergarden, but I have no other choice because this is verily a single speed issue.
Bikes: Klein Palmino, Litespeed Sienna
perhaps you could post a picture of your bikes? I'm sure it would help, and I'd like to see your "perfect" setup.
Can't be wrong. The proof of the pudding is in the eating and my bikes speak for themselves. If you have a problem with that then take it up with my bikes, because there's nothing I can do about it.
