how much can you bench press ?
Old 05-24-12 | 12:10 AM
I have never been much of a weight lifter, in fact I rarely lift weights. However, 3 months ago I decided to hit the gym and lift weights 3 times a week. So far I am making it about twice a week but oh well. The thing that really strikes me in the gym is that EVERY single male is bigger and stronger than me. I weigh 122 lbs but right now my max bench press is 155 lbs which I thought was pretty good for never lifting weights.
Surfer34 is offline
Reply
Old 05-24-12 | 12:31 AM
Bikepacker67's Avatar
Bikes: LHT, Kona Smoke
At 122lbs it isn't really surprising that most males are "stronger" than you.
Afterall, they're carrying around all that extra weight all the time.
Now the thing is, if you stick to weight-training as a smaller guy, you'll probably see significant gains much faster than a galoot like me.
And you'll be cut like greek god.
Bikepacker67 is offline
Reply
Old 05-24-12 | 03:45 AM
OldsCOOL's Avatar
20 Anniversary
I'd rather be lean and mean than to look like the dad on that Orange County chopper show.
That said, my max is 385lbs on the bench, in competition form (pause) at a bodyweight of 179.
When I hit 52 I was still doing 350lbs at the end of the bench workout in a gym with lots of surprised witnesses.
OldsCOOL is offline
Reply
Old 05-24-12 | 04:03 AM
wahoonc's Avatar
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
I don't worry about it too much. I do some strength training, but could care less about the total weight versus someone else. My satisfaction comes from knowing that at 50+ I am in a lot better shape than a lot of 35-40 year olds I see.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"
_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"
_krazygluon
wahoonc is offline
Reply
Old 05-24-12 | 09:02 AM
Bikes: 8
How high up a wall can you wee.. how fast can you play 'Orange Blossom Special'.
same thing.
its the squats and leg presses that get you moving with more power on the bike.
fietsbob is offline
Reply
Old 05-24-12 | 11:16 AM
"6"...yeah "6".
I won't say 6 what or how often. But I will say, "6".
What that has to do with anything, I have no idea.
But I'll stick with "6".
drmweaver2 is offline
Reply
Old 05-24-12 | 05:28 PM
ThermionicScott's Avatar
10 Anniversary
Bench press is overrated.
ThermionicScott is offline
Reply
Old 05-24-12 | 06:16 PM
peckma's Avatar
Bikes: 2013 BMC GRAN FONDO GF01, 2010 SPECIALIZED ROUBAIX, 2004 TREK FX7000, 2013 SPECIALIZED ALLEZ
Not sure that (fill in name of your favorite pro cyclist) worries about how much they can bench. It's how fast/hard/long/efficiently, etc he can ride the bike. If cycling is your sport of choice - tailor your weight training for it, and stop worrying about the bench press.
155# for a body weight of 122#, is pretty good. I'd at least maintain it.
peckma is offline
Reply
Old 05-24-12 | 07:57 PM
Savagewolf's Avatar
KingoftheMountain wannabe
Bikes: V.O. Pass Hunter & Specialized Hardrock
Max bench (or any other exercise) is less valuable than how many times you can do a similar exercise. I'm more impressed by someone who can bench 200 pounds 40 times then by someone who can bench 250 one time. Even the NFL uses this as a major measure of stregnth, having players do reps of 225 during the rookie combine.
Savagewolf is offline
Reply
Old 05-24-12 | 08:07 PM
Bikes: 2010 Felt DA, 2012/6 Felt F5, 2015 Felt AR FRD
Back in the early days, as a freshmen in college, I weighed 185 lbs and could bench 300 lbs, once. That was way before I even thought about riding a bike. I'll also say that I probably had the endurance of a fat sloth. I was very strong for my size, but I seriously douobt I could have jogged a mile without being way too winded. Fast forward about 7 years, and I weigh about 12 lbs less, have no idea how much I could bench, as I haven't lifted weights in over 5 years, but can jog 5 miles, and regularly bike 40.
I would guess that I would be luck to bench my own weight. I would tell anyone that I'm much healthier now, but I do feel like I've traded strength for endurance.
KBentley57 is offline
Reply
Old 05-24-12 | 09:55 PM
Bikes: 2012 Specialized Crux, Schwinn Mesa
Bench press is most important when you consider your body weight vs. your max bench weight. For example lots of law enforcement agencies require you to take the cooper fitness test. To pass the benchpress portion you are expected to bench 80% of your body weight. So by that measure for you to be benching 150 and only weigh 120 your doing damn good. As was already mentioned though, being able to do reps with your body weight I.E. weighing 120 and benching reps of 120 is still a better measure of strength.
Mondo734 is offline
Reply
Old 05-24-12 | 11:49 PM
Nice i weigh around 135 and can max out at 185 not to bad,but then again i tried weights for alittle bit i tried all the powders and all that ate like a tank and didnt gain any weight at all beside 2 pounds in a month and to me for the extra 150 i spent on food and powders wasnt worth it to me.
kaptainscoot is offline
Reply
Old 05-24-12 | 11:57 PM
Sixty Fiver's Avatar
Bicycle Repair Man !!!
Bikes: See my sig...
When I worked out in the gym many many years ago I was happy with being able to bench 160 when I weighed 135 pounds and held the leg press record at the same gym based on % of weight to the lift.
Primarily worked on endurance for martial arts, rock climbing, and cycling where packing extra weight is a handicap and it was only when I went into working and wrestling with steel on a daily basis that I added much upper body mass and got some really huge legs.
Sixty Fiver is offline
Reply
Old 05-24-12 | 11:59 PM
IthaDan's Avatar
Bikes: Click on the #YOLO
Lifted 250#- after a 15 year hiatus from lifting- twice a week back.
I'm 6' 205 FWIW.
IthaDan is offline
Reply
Old 05-25-12 | 09:49 AM
10 Anniversary
Did you do any lifts besides bench? Squats are where it's at.
Reply
Old 05-25-12 | 09:55 AM
I can bench press both girlfriends if they hang on to the bar......
Booger1 is offline
Reply
Old 05-25-12 | 10:02 AM
mymojo's Avatar
Bikes: '10 Specialized Allez, '09 Cervelo S1, '93 Trek T200 (tandem), Rocky Mountain Metro 30
OK first, for context, I'm a clyde with a linebacker frame. Back in the day I could do 425# for three reps. I maxed @ 455# and blew out a shoulder trying 475#. I had to quit benching for a year because of that. And the biggest insult of it all was that my workout partnter put up 525# that day. I hurt myself because I stupidly tried to keep up with him. That's when I quit worrying about max bench. the point is, that no matter what your number is, there is someone who can do more - just like average speed.
Of course, I'm 15 years older now, and even in my best shape (which I'm not in) I couldnt come anywhere near that. In fact, if I could work back up to a max of 315# I'd be really happy.
Besides, your body type isn't meant for heavy lifting. Just like mine isn't meant to fit into euro cut jerseys.
mymojo is offline
Reply
Old 05-25-12 | 10:15 AM
Farmer Dave's Avatar
Bikes: 2010 Globe Vienna Disc 3
I'm 6 foot and weigh 123 lbs. I lift weights as well but my max for bench is 110. The fact that you are benching 30lbs over your body weight is exceptional! Really, good job and keep it up. I know how you feel man, I get looks all the time at the gym from meat heads, I just shrug and say, "Gotta start somewhere." You are doing awesome man don't trip.
Farmer Dave is offline
Reply
Old 05-25-12 | 05:23 PM
As a former college football player and competitive power lifter, bench press is waaaaay behind lifts like squats or cleans or deadlifts in relevance to athletic performance in just about any sport.
Asking about bench press on a cycling forum is about as relevant as asking if someone can breath the atmosphere on Neptune.
achoo is offline
Reply
Old 05-25-12 | 05:29 PM
ahsposo's Avatar
Artificial Member
Titanium Club Membership
15 Anniversary
Community Builder
Active Streak: 30 Days
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Just curious OP.
122#'s and how tall?
ahsposo is offline
Reply
Old 05-25-12 | 05:35 PM
wphamilton's Avatar
Bikes: Nashbar Road
I could bench 250 in high school (weighed 135) and have never checked since. Bench press really isn't important with respect to, well, anything.
wphamilton is offline
Reply
Old 05-25-12 | 05:38 PM
ahsposo's Avatar
Artificial Member
15 Anniversary
Community Builder
Except that's pretty impressive.
ahsposo is offline
Reply
Old 05-25-12 | 08:29 PM
Axiom's Avatar
Fat Cyclist
Bikes: '11 Cannondale SuperSix Dura-Ace
I don't like the bench press so I rarely do it. My one rep max is about the same, but when I am training I usually do 120.
Axiom is offline
Reply
Old 05-26-12 | 09:23 AM
wphamilton's Avatar
Bikes: Nashbar Road
Thanks, I thought so at the time with the ubiquitous self-centered world view of youth, but of course it wasn't that exceptional. People develop the ability to press insane amounts of weight. My unqualified advise is to forget about maximum bench press and just concentrate on pushups along with full-body exercises.
Reply
Old 05-26-12 | 09:43 AM
Mr. Beanz's Avatar
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Back when I was 220 I'd work my way up to 330 while pyramiding up in weight. I worked out alone so I never had a spotter so I never really maxed out.
my bench press workout:
135 lbs- s ets of 15 reps to warm up
185 10 reps still warming up
225 10 reps
250 8 reps
275 6 reps
300 3 reps
330 1 rep
then down
250 4 reps
220 10 reps
135 20 reps
then incline bench:
180 10 reps 3 sets then off to the pec deck for high rep light weight concentrated movements.
and yes, I had no problem riding a 5 1/2 hour century on a bicycle.
Doesn't show all the equipment I had but an idea. Squat rack on the opposite side of the room.
IMG_4718 by gulpxtreme, on Flickr
IMG_4717 by gulpxtreme, on Flickr
Mr. Beanz is offline
Reply
