Proper tool for 3-notch headset ring?
Kind of an aside, but as far as I could work out, the main point of these double locknut headsets was to allow regular people to take off the CPSC required front reflector. Nobody wanted those things. If they took them off and they didn't know how to adjust a headset, the bike could get screwed up. With the extra notched locknut, the headset stayed adjusted.
Quoted: 7359 Post(s)
Liked 2,497 Times
@Grand Bois, I don't think you've ever hidden your OCD.
Quoted: 289 Post(s)
Liked 331 Times
I suppose this is true, but perhaps a more useful application is with a cable hanger. Which leads me to my question: how tight should these be installed? My guess is tight enough to keep the adjustable cup in place, but no tighter.
Quoted: 4722 Post(s)
Liked 3,044 Times
The design predates the CPSC, going back to at least the mid-1960s. However, it would provide a similar benefit in cases where people might be switching between side-pull and centre-pull brakes and installing or removing a headset mounted cable hanger.
Thanks. OK, the extra lock nut was originally for the cable hanger then. That feature certainly did come in handy a few years later when CPSC reflectors became the norm. Removing reflectors was more common than swapping brakes.
Quoted: 3817 Post(s)
Liked 6,742 Times
So an update on the quest for the proper tool for this headset ring. I ordered three different ones: the first was a Pedro's Trixie multitool:
Untitled
It's close, but the curve isn't quite right and the tool itself is a bit too thick for the relatively thin 3-notch ring.
Next was a hooked-ring spanner that's designed for motorcycle applications. This wasn't going to work as it's much too thick and not the right profile:
Untitled
Today my Hozan C-205 lockring wrench arrived, and as several indicated in this thread, the fit seems right on:
Untitled
Untitled
Untitled
I'm a bit surprised that none of you old wrenches mentioned the previous version of this wrench, which a friend of mine had in his tool box:
Untitled
Hmm.
Untitled
Untitled
Untitled
Untitled
Untitled
Untitled
Hmm.
Disraeli Gears
Is that a photographic spoof? If not, right up there with Raundonner. Crassic!
Hozan is what I found in the bottom of my toolbox (and used) over the weekend.
Liked 6,742 Times
Quoted: 473 Post(s)
Liked 1,068 Times
This strategy also means that hook wrench can be used on other sized lock rings - appropriate spacer for each.
WGB
Bikes: Panasonic PT-4500
Quoted: 1805 Post(s)
Liked 2,343 Times
Lazyass
I have had two bikes now with these 3 notch headset rings and the first one I really scuffed with a wrench and don't want to repeat the same mistake. You posted "An AR15 spanner works. I know from experience. You can get them cheap"
When I was in the Canadian military I carried an FN 7.62 rifle and the C-8 5.56 rifles came in just as I left so I never completed the conversion and can't even recall ever seeing the wrench.
Can you advise if this link is for the wrench you are talking about?? The one on the ad looks like it has the right type of notches that would fit, just wanted to be sure
https://www.brownells.com/gunsmith-t...prod16882.aspx
Quoted: 796 Post(s)
Liked 522 Times
I had the same issue on an 87 Nishiki Cresta GT, should have bought the Hozan tool above did not, bought and tried 3 different tools that all failed.
Solution - LBS and a new headset from VO so I never have to see that #$%*&&!@ lock ring again
Old fart
Quoted: 3601 Post(s)
Liked 3,426 Times
mikeybikes
Bicycle Mechanics
3
03-19-10 11:17 PM
